"Cooling" with button fans.
During the summer I have got by with a 4" button fan about 98% of the time. With this dry air I am ok as long as the indoor temp is below 80F.
Dug out a 3" button fan and thought I would reduce energy usage by ~ 50%. Wired it up and was pleased that the net effect was at least as good. Feeling proud I compared the stated watt consumption of the two fans:
4" fan - 9.5 watts Must turn at a much lower velocity. Or a more efficient motor/German engineering? Or false advertising?
3" fan - 10.5 watts
The 3" fan is slightly louder and safer because there is less room to stick a finger in. Think I'll use it instead. I know the big room fan uses significant energy. Larger room fans often use at least 100-300 watts in my "experience".
They don't "technically cool" but they get the job done.
You need to look at the data sheets... More or less a small diameter fan with high airflow is going to be less efficient than a large fan turning slowly with similar airflow.
Small high RPM fans tend to be noisy too--And may have shorter bearing life.
I used to install button fans on reef tanks to push out the heat created by VHO lighting. They all had the same manufacturer so the 3" fans had about 1/2 the output of the 4" fans. I had a box around here if they have not been stolen. Would be interesting to see the wattage.BB. said:You need to look at the data sheets... More or less a small diameter fan with high airflow is going to be less efficient than a large fan turning slowly with similar airflow.
Your logic is sound but overlooks that the higher air speed, created by higher rpms , may be more pleasant than the higher CFM rating of a larger fan at lower rpms. Noise can also be good with three dogs. The odds of one of them being noisy are pretty good.
Update:
They are often called muffin fans. Here is a very quiet unit that consumes 4 watts at 60Hz (USA): https://www.amazon.com/AC-Infinity-Cooling-Ventilation-Projects/dp/B009OXTWZI/ref=sr_1_4?keywords=140mm+fan+120+volt+low+speed&qid=1565810796&s=gateway&sr=8-4#customerReviewsFirst Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
I use DC computer fans for sleeping. Three in a simple box work well. Where I am it cools down a lot at night. I use a simple FET and capacitor and it shuts down about an hour and a half after I go to bed. Otherwise I would wake up from the chill in the middle of the night.
I live in kind of a big bunker. No windows on a 400' bedroom. Many walls that are ~ foot thick. Light is provided by tubular ceiling lights that work very well when the sun is shining.NANOcontrol said:I use DC computer fans for sleeping. Three in a simple box work well. Where I am it cools down a lot at night. I use a simple FET and capacitor and it shuts down about an hour and a half after I go to bed. Otherwise I would wake up from the chill in the middle of the night.
Windows are nice but weak in the security area. When in Denver I consider how easy it would be to whack somebody with a cracked open window. Why they shoot people instead is a curiousity. Perhaps to send a message. Talk about epic thread drift - my specialty.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
That 1225 muffin 51 cfm 8 watts looks interesting. Don't know the cfm but I use a 14" dc 12 volt fantastic breeze 3 years old. runs all night 6 months out the year. 13 watts on low. I am really impressed with the amount of air it moves. Too much air on high for a camper bedroom. Not the quietest. And kinda pricey.2kw array 6 345 q cells make sky blue 60 cc
6 230ah GC @36 volts
18 amp accusense charger. 3650 champion -
We use ryobi 18v fan for sleeping . Living room 120v dc ceiling fan. Inverter is off at nightOff grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat
I like the 10” o2 fans they use 10 watts on low and 13 watts on high . My 68” ceiling fan uses 20 watts on low and 100 watts on high . It stays 67o in the house all summer so my fans are needed to move heat . The other morning it was 47o out side , I’m going to have to start burning again soonOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
Are those the "o2 Cool" fans that run on 8 D cell batteries or 120Ac to 12 Vdc wall wart?
The newer model is now 9 volt, and may use even less wattage, but no longer 12v...littleharbor2 said:Are those the "o2 Cool" fans that run on 8 D cell batteries or 120Ac to 12 Vdc wall wart?
The wall wart outputs 9Vdc .7 amps. Perhaps they still make the camping base model? The one's without the fold out base also take batteries.
I've got one running now and have used them for 10+ years now. The ones I keep running nearly 24/7 in the summer/6 months and sporadically other times last 2-3 years. Not simple to clean out, about 9-12 screws to open and clean blades.
I had mine, in the 5th wheel set up with a 12 volt cigarette lighter plug power source. How would a 9 volt model work in this scenario? Is there an optional power cord for them? Mine are all about 10 years old as well.
I'm using a little buck converter to run 9v load off 12vdc bank:
https://www.amazon.ca/Converter-Voltage-Regulator-Efficiency-Lanpu/dp/B07CS69HT4/ref=mp_s_a_1_3?keywords=buck+converter&qid=1565963916&s=gateway&sprefix=buck+&sr=8-3
I’ve had good luck using a Caframo Ultimate. It uses less than 0.5 amps at 12v.
https://www.amazon.com/gp/product/B0016013JK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1&psc=1
Caframo has quite a few models. Some made in Canada. Check out the new Sirocco II Elite with brushless motor.
https://www.caframolifestylesolutions.com/support/Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries -
LH , yes that is similar to what I have .
Mine are 6/7 years old now and run a lot .
I think i used one with battery’s for a complet season with one set of battery’s .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Yep, 8 D cells hold a fair amount of power. They also work as ballast to keep the fan from toppling over. I had one at home for my wife. It ran off of a wall wart and I substituted Ziplock sand bags for battery ballast.
You keep saying wall wart - and I never heard of this wart.littleharbor2 said:Yep, 8 D cells hold a fair amount of power. They also work as ballast to keep the fan from toppling over. I had one at home for my wife. It ran off of a wall wart and I substituted Ziplock sand bags for battery ballast.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Wall wart (noun) - a protuberance extending from an AC outlet, typically converting higher voltage AC current to lower voltage DC current for DC loads like laptops or LED lighting. Can be a "vampire load", sucking power even while doing nothing useful. Some don't play well with MSW AC power. Some just don't play well.Off-grid.
Is it worth $18 to save ~ 5 watts and have a slightly quieter fan with less volume? Probably so - when you want less volume and noise. As for 5 watts? I probably have a few "vampire loads" bigger than that. I've got too much stuff to sweat all the little bitty details.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
All those little black cubes that plug into the typical outlet and connect to all the devices we use these days. Generally they convert AC to DC and are of varying low voltage output. 1.5 volts Vdc 4.5 Vdc, 12 Vdc, etc.softdown said:
It's been true I the past, but most are 'smart' these days and don't draw any noticeable current. In fact it was running one of these O2cool fans off a cheap WalMart Battery charger adapter when I realized it would be warm even without the fan on. I switched it out for the onethat came with the fan and no more warm warts...Estragon said:Wall wart (noun) - a protuberance extending from an AC outlet, typically converting higher voltage AC current to lower voltage DC current for DC loads like laptops or LED lighting. Can be a "vampire load", sucking power even while doing nothing useful. Some don't play well with MSW AC power. Some just don't play well.
I don't see an advantage to using a 12 volt fan when a voltage converter is required. Though saying you have wall warts is sure to stymie a few.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
The O2 cool is a D cell battery powered fan that has a 12 volt optional power in port. How you get power to it is up to the user. Cigarette lighter port, wall wart , squirrel running in a ferris wheel, pedal powered generator, etc.
