mppt solar charge controller t60-150
aspiringpisces
Registered Users Posts: 4 ✭
can I connect 3 sets of 4 38.8 volt panels in series in parallel on a mppt t60-150 charge controller
Four panels in series will be problematic. Is the voltage shown the Voc. or Vmp.? What are the other stats of your panels? Watt rating? Another consideration is what is your system voltage? You may, or may not have too much panel for a 60 amp controller, depending on system voltage.
This link will assist in designing the optimal arrangement with your particular panels, assuming you are referring to the Morningstar T 60 MPPT http://string-calculator.morningstarcorp.comaspiringpisces said:can I connect 3 sets of 4 38.8 volt panels in series in parallel on a mppt t60-150 charge controller1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
From the description given it sounds like a Schneider Conext 60-150 charge controller . If they have a string sizing tool I couldn't find it. Their site is not easy to navigate.
Don't believe Schneider has one anymore, the t60-150 made me think TriStar, either way both have identical voltage specs, I actually refered to Morningstar string calculator for my Schneider 60-150.littleharbor2 said:From the description given it sounds like a Schneider Conext 60-150 charge controller . If they have a string sizing tool I couldn't find it. Their site is not easy to navigate.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
