mppt solar charge controller t60-150
aspiringpisces
aspiringpisces Registered Users Posts: 4
 can I connect  3 sets of 4  38.8 volt panels in series in parallel  on a mppt t60-150 charge controller
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,189 ✭✭✭✭✭
    Four panels in series will be problematic. Is the voltage shown the Voc. or Vmp.? What are the other stats of your panels? Watt rating? Another consideration is what is your system voltage? You may, or may not have too much panel for a 60 amp controller, depending on system voltage.
  • mcgivor
    This link will assist in designing the optimal arrangement with your particular panels, assuming you are referring to the Morningstar T 60 MPPT  http://string-calculator.morningstarcorp.com
  • littleharbor2
    edited July 2019 #4
    From the description given it sounds like a Schneider Conext 60-150 charge controller . If they have a string sizing tool I couldn't find it. Their site is not easy to navigate.
  • mcgivor
    Don't believe Schneider has one anymore, the t60-150 made me think TriStar, either way both have identical voltage specs, I actually refered to Morningstar string calculator for my Schneider 60-150.
