My older batteries are behaving odd...to me
northernsun
northernsun Registered Users Posts: 8 ✭✭
My off grid solar system dates from my 2007, I have been its sole operator. The system consists of an xantrex sw-4024, 4x crown cr-395 in series for 24v nominal. The current panel and charger configuration is 6x 305w panels, a midnight classic with a wizbang and endamp charging enabled. I've added a diversion load last year and I've noticed a funny phenomeneon. When the diversion load is active the battery voltage drops from 28.8 to 27.6 even though the net amps are still in the positive ( around 6-7 amps).I should add that when I check the SG of the batteries all cells are getting a good charge (SG 1.275-1.285). Is there a technical explination for whats going on here? My suspicion is that it has something to do with the age of the batteries although I'd love to hear a more detailed explanation.
6x Hanwha Solar G4 305watts
Midnight Solar Classic 150 w/ wizbang jr
2x 314 ah lifepo batteries 24v with Jk BMS
Xantrex SW4024
location - Lanaudiere, Quebec, Canada
  • mcgivor
    What you are seeing is probably something normal but may be potentially damaging to the batteries if I'm understanding correctly what it is you are doing. By adding a load during charging it is possible that if the load is large enough it would drag the voltage down, the array may not be able to both support the charging and load together.
    Using the 28.8V figure would indicate the batteries are still charging, the diversion load could potentially prevent a complete charging cycle. This may, if done on a daily basis over an extended period cause undercharging related problems.
    To understand more clearly could you provide details related to how this diversion load is connected, how large and for how long, how often etcetera.
  • Estragon
    Does the voltage recover fairly quickly (a few seconds to minutes)?  If so, I think that would be pretty normal.  The controller may take a few seconds to sweep a new I/V curve, and a bit more to get the bank back to target voltage.  I often see this when powering a pump or whatever mid-day.
    If the voltage sag lasts more than a minute or so, pv may not be sufficient to power both the load and charging, as mcgivor suggests.
  • northernsun
    edited July 2019 #4
    As I've mentioned in my initial post, when the diversion load is active in good sun I'm seeing a net charge of 6 or 7 amps, roughly 35 amps as system load and 40 amps coming from the charger. I'm getting those numbers from both the Wizbang jr and my trimetric. The diversion load is triggered by the midnight classic (waste not Hi). I guess what I'm really asking is how its possible to have a positive charge to the battery and have voltage drop at the same time? I shoud also mention that I'm hitting float via endamps charge pretty much every day, so I'm not overly concerned, just curious.
    Xantrex SW4024
  • Estragon
    It's possible for voltage to drop even with positive amps to the battery.  Basically it takes 'X' amps to get to and maintain 'Y' volts.  To maintain float (~26-27v) on a full bank, for example, may take ~1% of AH capacity.  In absorb (~29v), it might take anywhere from ~2% to 15-20% depending on SOC etc.  If the 6a remaining after loads isn't enough to hold 28.8v, voltage will drop to whatever can be held with available current.
    I suspect you have your diversion load set to begin when you hit float and you are just seeing the natural switching of the charge controller dropping into float. At  27.6 volts and a SG of 12.75, you are fully charged.  I might even suggest lowering the float voltage to 26.6-27.2.
