spacebass: What solar panels for 36 volt battery bus
System Posts: 93 admin
edited July 2019 in Solar Beginners Corner #1
This discussion was created from comments split from: 24v panel with 12v battery.
From SpaceBass:
BB. said:
We need some more details... How big of solar array (Watts), what is the coldest temperature in your area, what voltage battery bank (12/24/36/48 volt), and what type battery (flooded cell, AGM, etc.)? Do you plan on making your system larger? Do you want "simple" or "remote monitoring" and other features?
Bill, if your 'details' is directed at me, I intend to buy a 60 amp multi voltage mppt controller , I have 4 x 330 watt 24 volt mono panels I want to use , 2 x 210 Ah 12 volt deep cycle wet batteries I want to add a third for 36 volts.haven't worked out the inverter yet. I live in Thailand 30'. Cannot find a 36 volt inverter.
https://s.lazada.co.th/s.Ze4LI
  • spacebass
    spacebass Registered Users Posts: 87 ✭✭
    What panels would you use with 36 volt mppt controller ?
    BB. Super Moderators, Administrators Posts: 33,687 admin
    Spacebass,
    I will move your Q&A to its own thread... It should be less confusing--Especially if Tordfish comes back.
    There are some 36 volt AC inverters out there... I think 36 volts battery bus was sort of common for larger (private?) boats in decades past.
    https://www.amazon.com/36-volt-inverter/s?k=36+volt+inverter (USA search results)
    For off grid solar power, 12/24/48 VDC battery is much more common... 36 volts is sort of a 1/2 step in the bus voltage progression and you may not want to paint yourself into a corner (find a 36 volt AC inverter, but 5+ years down the road, hard to find replacement). Also, if you need a 36 volt AC battery charger (utility/genset charging)--Your 36 volt charging choices are going to be a bit thin.
    Your MPPT (English translation) MPPT charge controller link has some nice documentation:
    • 12v system can receive from DC 18v-DC 150v
    • 24v system can receive from DC 34v-DC 150v
    • 48v system can receive from DC 65v-DC 150v
    However, the basic specification does "gloss over" the realities of solar panels... The "24 volt panel" generally have Vmp in the range of 30-36 volts at 25C cell temperature (room temperature) ... But we need to know your "exact" Vmp-std rating for your panel to figure out the hot derating (and for cold climates, Voc-std for cold deratings).
    For example, in warm to hot weather, yorr Vmp falls from 30 volts to ~24 volts (almost a 20% drop)... And your MPPT controller really wants to be 1.3x your battery bank voltage... When this is all thrown together, your Vmp-array-std rating should be a minimum of:
    • 30 volts battery charging * 1.3 minimum MPPT suggested operating point (ideal) * 1/0.80 Vmp-hot derating = 48.75 volt Vmp-array-std
    So, at the very least, for a 24 VDC battery bus, you should put two of your "24 volt" panels in series.
    If you had a 36 volt battery bus:
    • 45 volt batt charging * 1.3 mppt minimum voltage * 1/0.80 hot panel deratring = 73.125 Vmp-array-std minimum
    And here is where Vmp=30 volts vs Vmp=36 volts (for your 330 Watt panels) make a difference... 2x30v=60 volt Vmp-array-std (not ideal for MPPT on 36 volt bus) vs 2x36 volt = 72 volt array (close enough to work).
    And then you have the issue of 3xVoc-cold for the panels... In cold regions, that could be an issue in subzero conditions (Voc-array-cold>150 VDC max input)--But you are in Thailand, so probably not an issue.
    "Higher voltage" Solar Panels can be kind of a pain when matching to battery bank and Vpanel-max ratings for charge controllers...
    Details matter here--
  • spacebass
    edited July 2019 #5
    Thank You for comprehensive answer I need to go back to school for a long time !! One of the main reasons I am moving to the Applegreen mppt controller is that it is about 8% overall more efficient than the Epever Tracer 40 amp and handles more input volts Iand amps. I looked at 36 volts as a way of increasing battery capacity but does not seem practical .My novice experience with the Epever Tracer 40 amp is that it seems to do good mppt uprating of amps but 40 amp? In the hand book it says : ' 24 volt Best Configuration 1 panel Maximum 2 panels'  and when I had 4 panels on it the 60 amp breaker between controller and batteries was breaking.  On the face of it why would anyone buy a 40 amp controller for 1 panel?
    The Apple green controller does cost nearly twice as much as the Epever Tracer there is a 30 amp version plus 50% on Epever.
    N
    I have 2 x 24 volt panels in series should I add a third in series To get optimum voltage in the heat ?
    Still need the nameplate voltages/currents for your proposed panels...
    Roughly, 2x battery voltage --- Probably ideal for efficiency. The higher the voltage difference from Array to Battery bank, the (a little bit) less efficient MPPT charge controller--But I would not make a big deal out of that "loss of efficiency" (a couple of percent difference).
    If you have a "long wire run" from array to charge controller+battery shed, having higher Vmp-array allows you to use smaller diameter wiring for the array/install array farther away.
    Other issues--When you have 3 series x 2 parallel strings, you do not need inline fuses/breakers for array safety. With 2 series x 3 parallel, you should have series protection fuses/breaker (typically ~15 amps--Check the panel specifications) with a combiner box (more hardware, more expenses).
    Having a breaker/switch on the array and on the Controller to Battery bank allows you to turn on/off the array (and controller) while working the system. Note: Turn on Battery first, and turn off battery last (turn on array last, turn off array first). You want the charge controller running off of battery power before solar array power. The battery power configures the controller for 12/24 volts and protects against solar array "voltage surges to the output" that could damage the charge controller.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,123 ✭✭✭✭✭
    Never heard of Apple Green brand controller but if it will do 48 volts you can have a much larger (double) solar array and battery bank than a 24 volt system.
  • spacebass
    edited July 2019 #8
    Bill, I am getting 70 volts on Tracer mt 50 remote 2 panels in series, was showing 80 volts with 4 panels 2 strings.
    Panel Spec : Pmax 340,Vmp 38.15,Imp 8.91,Voc 46.26, Isc9.45 ,efficiency 17.5 %
    No long runs about 15 feet panels controller I have 40 amp breaker in panel supply , I know too big .
    It is 0800 I have 63 volts from panels this will rise to around 70 volts.
    This system is up and running in the new system referred to I was going to utilise the 2 removed panels and buy the other bits , i.e. upgrade the mppt controller in this system to applegreen and move epever tracer to new system for inverter air con at night only .
    spacebass said:
    …. when I had 4 panels on it the 60 amp breaker between controller and batteries was breaking....
    Was this a DC rated breaker? How many amps were you passing through it?
  • spacebass
    edited July 2019 #10
    Hi this is an auto audio DC breaker marked battery /accessory on the poles. I don't know how many amps are passing through the breaker when it breaks but I believe the 40 amp tracer AN controller is somehow tripping the breaker when it gets over spec'd volts or amps going on because it says in the handbook it will disconnect accessories when this happens and then reconnect them when normality returns but of course it cannot reconnect a breaker. With regard to this disconnection for what I believe is too many panels (4x24volt) for the controller to handle even though it looks OK on paper running with two panels it does not happen.
    Now a new circumstance where the breaker goes in the day with two panels connected after a long period of intense sunshine  leaving on the tracer MT- 50 remote screen a full battery icon and 27 volts + in the battery , I believe the tracer controller has tripped the 60 amp breaker because of too much something the point being that it may have legitimately tripped the breaker but cannot restore the system back to working as it presumably could if the breaker was not there.
    I am ditching this Tracer controller I think it is good from an mppt charging  point of view but cannot handle the tropical sun.
    I am going to buy an Applegreen mppt controller costs nearly twice as much as the Tracer.
    https://s.lazada.co.th/s.ZVlUJ
  • mcgivor
    If the Tracer is 40A it's output would be limited to that current, so the problem probably lies in the beaker. Automotive breakersare not rated for continuous high current, they are also thermal which means if used in hot climates their trip value will be reduced, they also have a tollerance + or - 10% for example. One 10A breaker I have will trip at < 7A if the ambient is 40°C, at 35°C it's fine, there are electromagnetic types which are not affected by temperature to the same degree.
    Has the current actually been measured and dose the breaker get hot?
  • littleharbor2
    edited July 2019 #12
    Automotive audio breaker, is it rated for 12 volts and you are running how many volts through it? Could be a problem there.
  • spacebass
    A lot of these breakers state 12v 24 v but it would not surprise me if they were lying.
  • spacebass
    edited July 2019 #14
    If the Tracer limits current to 40 amp as I believe it is supposed to and states in handbook it disconnects things if electricity goes out of spec why do people need a breaker ? It is removing some of the utility of the controller i.e. the ability to reset operation after cloedown.sfter spike.
  • Estragon
    The breaker is there to protect wire in a fault condition, most likely of which being a short in the controller.  Absent the breaker, 100's to 1000's of amps from batteries could flow across the short.
  • spacebass
    Does that just mean the controller is toast ?
  • Estragon
    If the controller is shorting, yes.
    Or if not exceeding 40 amps, a bad breaker.
    Bill
