Morningstar vs Victron
jrcent
Registered Users Posts: 47 ✭✭
I'm trying to decide which charge controller to use for my night 12v system.
I think I have it narrowed down to the 75/15 victron and the morningstar sunsaver 75/15. I already have the morningstar 300w sunsaver inverter. They both have good specs. They both are about the same price. I see more reviews for the victron but haven't seen any bad reviews for the morningstar. Is there anything I've missed that would make one or the other a better choice? Thanks for any help.
Morningstar has been making very solid charge controllers for years. I like them
Thanks. I've seen some of the reviews for their own and older controllers that lasted for years.
I'm partial to the morningstar but it's hard to find much on them except that they work good and last long but hard to program. I already have the display from the sureshine. Very light load on the batteries.
With the victron I have been wondering how much the bluetooth loads the system being on constantly. They do have the Battery Life algorithm which sounds good. -
Morningstar tech support is outstanding, the product is rugged, TS 60 experience, somewhat simple on the surface but infinitely adjustable with MSview software, if applicable, would definitely recommend and purchase again. No experience with Victron.
I think Victron is bigger in the boat and European markets, MS more americas. Bluetooth does use some power. There's a low power version of bluetooth (ble) for short range (eg. a few feet with no obstructions) - don't know if Victron uses it.Off-grid.
I went with the morningstar. Thanks
jrcent said:
I'm partial to the morningstar but it's hard to find much on them except that they work good and last long but hard to program.Well, then maybe you should not be programming them. They have about the simplest and very intuitive interface I've seen. You will have to make the mental jump from 12 to 24 to 48V depending on your battery voltage. There are a few settings that have obscure names, but most folks with familarity with solar, should have no problem.( I've speaking of their MSView program, which is what I understand is used for all their gear)
https://www.morningstarcorp.com/msview/
Hard as in connectivity is more what I read about the programming what I could find in reviews. Not much reviews compared to other brands. But 90% of the reviews are from Chinese crap trying to convince someone that they didn't waste their money lol. I don't have a problem with the programming myself. Looks like I can just play and play also with a couple jumper settings but I guess I'll find out. That's why I went with the sunsaver 15a because it's so powerful for the price. The MS site actually has a lot of information about it and programming .
This will be my nighttime system running 12v using 400w panels, sureshine 300w inverter, sunsaver mppt 15a. Figured for the winter here that plus propane and generator will be good.
Still working on my daytime system. Right now at 24v but depending on the inverter I choose will be 24v or 48v. I like the lower amps of 48v but still researching -
Estragon said:I think Victron is bigger in the boat and European markets, MS more americas. Bluetooth does use some power. There's a low power version of bluetooth (ble) for short range (eg. a few feet with no obstructions) - don't know if Victron uses it.
I'm happy with my MS gear, FWIW.
Personally, bluetooth in a charge controller wouldn't be much use to me whether BLE or otherwise, but that's application specific. I can see where it might be.Off-grid.
https://www.morningstarcorp.com/msview/ -
I use the serial - USB interface. It HAS to be the tripp-lite U209-000-R, or an exact clone. All others leave out the power chip that is required to run the serial port side.That is the only "difficulty" getting it to work. ( and that you know how to count and click on the proper serial port in your system )I don't know if their sw runs on Mac.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
mike95490 said:I use the serial - USB interface. It HAS to be the tripp-lite U209-000-R, or an exact clone. All others leave out the power chip that is required to run the serial port side.That is the only "difficulty" getting it to work. ( and that you know how to count and click on the proper serial port in your system )I don't know if their sw runs on Mac.
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
