which panel would i need...
JoelKlemke
JoelKlemke Registered Users, Users Awaiting Email Confirmation Posts: 2
Hello all,
           I was thinking of making my own solar powered attic fan. If I wanted to run this fan(from a race car - draws 14 amps):
How many watt panel would it take to run that at a decent speed,please? 25, 40 watts?
Thank you in advance!
JK
  • mcgivor
    That fan is not really suited for the intended application, it is designed to move large amounts of air for short durations across a radiator.
    The motor is most likely brushed which is not desirable, needing a battery to support it  during times of low panel output, clouds passing as an example, a brushless motor would br a better choice, something like this  (for reference purpose ) https://www.amazon.com/ECO-WORTHY-65-Watt-18-Volt-Efficient-Brushless/dp/B01MQRU3B1
    One thing to consider is passive ventilation, I had a house which cooked in the summer, a fan was installed which helped dramatically. After a number of years the motor failed, but there was no noticeable change in temperature inside the house, just having a vent near the roof peak was enough to create airflow which would otherwise be trapped.
  • Estragon
    Also lots of soffit venting, so ridge vents pull outside air (not conditioned air from living space).
  • JoelKlemke
    edited June 2019 #4
    Thank you all for the assistance!
    Mac, that fan is currently unavailable. May i please have your thoughts on this one, please?
    Have a great day!
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,093 ✭✭✭✭✭
    You can assemble the same set for less money.  The fans alone are usually less than $20.00. I have a pair of them in my garage powered by a hardwired old 65 watt panel. works great. Has for nearly 5 years now.
