Will someone tell me if I'm getting the wrong fuses?
blueskies
blueskies Registered Users Posts: 54 ✭✭
Does anyone see any problems with my fusing plans?  Much Appreciated!
I have 4 panels that will be in parallel to the Morningstar TS-MPPT-60M MPPT.  The four panels are rated at IMP 9.02 amps.  So I figure I would have a 45 amp fuse between the panels and the MPPT (9 amps in parallel times 4 times 1.25=45).
Between the MPPT and the batteries (24 volt) I figured I'd use a 90 amp fuse since the manual states:
Solar and battery fuses or DC breakers are required in the system. These protection devices are external to the TriStar MPPT 150V controller, and must be a maximum of 90 amps for the TS-MPPT-60
(I'm not sure why they don't want a 60 amp fuse but I'll take their word for it.)
Finally, I also have a Samlex 3000W Pure Sine Wave Inverter - 24V on the way.  Its manual has a table that states:
Maximum Continuous DC Input - 180 Amp
Minimum Ampacity of cable - 225 Amp
Maximum External Battery Fuse Size - 200 Amp
and they specify a Class T fast acting fuse.  I found a marine/RV fuse - Blue Sea 5116 Fuse A3T (Class T) 200 Amp that I figured I would use.
Thank you for keeping me out of the weeds and from burning down the trailer park!  (Beck Loser song)
  • Estragon
    Note that the breakerfusing specs are maximum for the devices.  Whether they're appropriate also depends on wire size, so you may want to check an NEC ampacity chart to ensure these sizes are appropriate for wire size in your installation.  These wires are generally somewhat oversized to minimize voltage drop.  If yours are also, the recommended fuse sizes should be fine.
    With four in parallel, you should really be fusing each panel (~15a) as well.
    Personally, I prefer breakers, but fuses work too.
  • Tecnodave
    Tecnodave Registered Users Posts: 437 ✭✭✭✭
    Blueskies,
    With 4 panels in parallel you really need a fuse on each panel. This is to prevent the occurrence of one failed shorted panel being set ablaze by the other 3 which will dump all their available power into the failing one. In solar use we often use DC breakers to do this task as well as a shutdown and diagnostic tool. I would recommend MidNite Solar MNEPV breakers contained in din rail breaker boxes, MidNite Big Baby box for indoor use or MidNite MNPV6 box for outdoor use.
    With all MPPT type controllers it is very important to energise the controller first, wait for it to initialize, then turn on p.v. Input. Applying p.v. volts first then battery can damage controllers. Also shutdown turn off solar first, wait a minute for accumulated power to drain off to battery, then shut down power to controller.
    So at the minimum you need a fuse or breaker for each panel as well as a fuse or breakers at the MPPT controller.
    For that controller I would use a 75 amp breaker and 75 amp rated wire as you do not want the breaker nuisance trip. The controller has internal current limiting at 60 amps but a 60 amp breaker will nuisance trip at 60 amps, a 75 amp or 90 amp breaker will not nuisance trip at 60 amps continuous.  Like I said in previous paragraph "you do not want a situation where you do have p.v. input power and no connection to the battery". This could lead to your controller taking a trip back to Mstar for repairs. Been there done that, one of my MidNite Kid controller has been home twice now for repairs after it lost battery power when operating with p.v. power in.
    So there is my reasoning for using breakers instead of fuses at least at the controller if not at the array itself.
    Inverter fusing.....good choice, go with the blue seas class T fuse.
    2 Classic 150, 2 Kid, 5 arrays 7.5 kw total  2ea.  2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200,  2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100,  2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B  dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4,
  • blueskies
    everytime i  think i know what i'm doing, you guys save my arse.  thank you from the bottom of my heart.
  • mcgivor
    Question, what panels are being used?
    The reason I ask is because parrallel wiring all the panels may not be the best configuration with the Morningstar TS 60 MPPT and a 24V nominal system.
  • Tecnodave
    @mcgivor,
    good catch on that issue, somehow I didn't connect 24 volts and MPPT, should have,,
    @blueskies
    Please tell us just what panels that you have, make, model, watts, volts,amps,  and number of cells....this will make a big difference in the best wiring scheme.
  • blueskies
    CanadianSolar Model CSU-355P times four, using parallel as there may be some minor shading.  Pmax 355  Watt / VMP 39.4 volt / IMP 9.02 Amp / VOC 46.8 V / ISC 9.59 Amps / Max series fuse (internal?) 30 Amps.  And I don't need T fuses on either side of MPPT - breakers would be better, is that right?
  • blueskies
    PS.  Lady in the house asks if the sun is getting brighter and weather is changing or it is her imagination.
  • Tecnodave
    @blueskies,
    you  can do all parallel with that high of voltage into an MPPT controller for a nominal 24 volt system, it will work fine, but do be sure to use at least fuses on each panel to prevent a disaster if one of the panels should short out, the others will have enough power to possibly set it on fire, panel fuses or breakers 15 amps
    With a VMP 39.4v,  and a 24V battery AND using a MPPT controller, I'd wire the panels 2S, 2P
    That gives the controller 80V to work with, you don't "need" panel fuses (but a breaker is handy for troubleshooting balance issues)
  • mcgivor
    Agree with 2S 2P, another benefit would be less voltage drop between array and controller.
  • Tecnodave
    as there might be some shading issues......
    a good  MPPT controller can work with a voltage conversion ratio of 1.3 to 1 which in this case is almost exactly that 1.368 to 1,   So two advantages to using all parallel less shading loss, slightly higher effeciency as the buck converter has a bit more effeciency at lower conversion ratios, though that will be minor with a difference of 1.3 and 2.7 (difference in conversion ratio between parallel and series) The real advantage is the shading issue.
    I haven't read anywhere as to the distance between the panels and the controller,
    and no t fuses for the controller,  breakers give you control as well as circuit protection
    and being a MidNite guy I have to admit that that Morningstar controller is one of the best that there is.
