Request recommendations for mppt controller
I’m no expert but the midnight classic is a good unit .
It would be my first choice but I have a outback system so I use a out back fm 80
its really easy to set up , and there are videos of all the procedures online .
I could not just read the manual and figure it out .
It’s a little tricky for a newbie like my self .
The fm 60 would work for you also .
I have a48 volt system with 5 strings of 3 295 watt panels run in Series .
My 2 cent JohnOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
I own 3 Midnite Classic's, but they Would NOT be my suggestion for an enclosed trailer if you were going to sleep or conduct business in it. There will be some fan noise. If it's just to be used for cargo, the folks at Midnite will be glad to work with you to fix the problem with your display, heck you will want to replace the display if you are going to resell it any way, but perhaps you returned it. Their manual is pretty complex at times, it has many advanced features.
I would likely point you toward a Morningstar MPPT TS 60, should be very reliable unit and no fans. Schneider Conext XW 60 would also be an option without fans.
Outback has a calculator that is a download, Morning star's is here;
http://string-calculator.morningstarcorp.com/
Have you tried to contact or left a message to MidNite service ?
If not, I would highly suggest doing that. They can also answer questions about the operation of the Classic.
360-403-7207 -
I have both the classic and the morningstar TSMPP-60.I would suggest the Morningstar. It has some relay set/ trigger ports I think, but I have never used them. The TSMPP-60 has a built in web server, which is useful for monitoring, stock, it does not come with a LCD display.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I only use the Schneider 600 volt MPPT. Morning star has a 600 volt also. They make all of the work at the array much easier.
You can use 2 strings of panels without fuses or breakers and just a regular Jbox to combine the strings.
High voltage also makes it easier to make changes later.
I would also suggest that you stay with Outback, Magnum, or Schneider in all devices so the system can be easily monitored and give useful data to you. Below is a link that I was given from Schneider. I have not run it
http://www.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/233000/FA233826/en_US/Conext_Designer_v1.16 (1).air?_ga=2.196879468.1765271633.1559744730-53987244.1559744730
To fix the forum "hashing" Dave's link:
http://www.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/233000/FA233826/en_US/Conext_Designer_v1.16%20(1).air?_ga=2.196879468.1765271633.1559744730-53987244.1559744730
This one should work if clicked on (I don't know what a ".air" file is).
An Adobe based installation file?
https://fileinfo.com/extension/air-BillAIR files are similar to the more common .EXE and .DMG files, which are used to install applications. However, AIR files can be used to install applications on multiple platforms, whereas EXE files and DMG files are restricted to Windows and macOS.
If you receive an AIR file you will need to install Adobe AIR on your computer in order to open the file. After you install the program, simply double-click the AIR file and the application will be installed on your computer. It is important to note that Windows Vista systems may not correctly register the ".air" file extension due to a locked file-type association in the registry.
NOTE: AIR stands for "Adobe Integrated Runtime" and is a multi-platform environment for running Internet-based applications on the desktop.
MidNite used Adobe AIR for our "Local App".... At the time, it was going to be a great way to go, kind of like what Microsoft Dot-Net was supposed to be, but of course, Adobe has basically stopped supporting new versions, so moot point
At least you can still download AIR from Adobe
