400 watt solar panel
Plucka
Registered Users Posts: 130 ✭✭
In Western Australia I tired to buy a 12 volt 400 watt solar panel.All the retailers I spoke to said they are fake and not 400 watt and tried to sell me a lesser wattage.Who is the con artist?.
It's unlikely to be a 12 volt nominal, 400 watt panel. Not sure how practical it would be as it would require multiple strings of cells running in parallel within the panels. I suspect they are correct. Any reason you don't want to run more than one panel in parallel?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I have 4 panels of 200 watts paralleled and set up as 2 x 400 watts each on the caravan roof but I need some extra charge but have no more room so I thought I'd put a 400 watt to swing out one on the side of the van [making it 3 solar controllers ].I would then have all inputs equal.
The included area of 2 × 200W or a 400w single if available, would still be the same, using smaller is often easier to handle, just a thought.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
You indicated this would be a third solar array/controller, then the panel voltage is irrelevant with the right solar controller. Get a MPPT 12/24 CC and it will automatically take the 24V panel voltage and convert it to your 12v system but at a higher amperage so that no energy is wasted.
That's the answer I was looking for .Thanks
- 232 Forum & Website
