Combox Log
stmar
Solar Expert Posts: 373 ✭✭✭
| Anybody seen something like this from their Combox log: | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Just checked and it keeps repeating. |
It sorta looks like debug output to me. A program will often have an option invoked with debug switch (eg. myprog -d) for diagnostic purposes. In this case, it looks like debug for writing/rolling logfiles.Off-grid.
Yes what Estragon said! Pretty normal. Started about 2 years back to fix and avoid issues."we go where power lines don't" Sierra Nevada mountain area
I heard something in the middle of the night, don't know if it was anything to do with the system, but when I checked it the Combox lights were going through their start up sequence. I logged in and found the above Events, no Warnings. At that point since it was 3 AM I disconnected the Combox and SCP. This morning reconnected and everything seems fine but still generating lines as earlier. Will let it run today and see what happens.
2019/05/12 08:40:00 Old Epoch:2019-5-12 8:39:59 New Epoch:2019-5-12 8:40:0 new10mins. 2019/05/12 08:37:35 Login: admin 2019/05/12 08:36:10 Created Xanbus Device: SCP ( 1681104 ) 2019/05/12 08:36:09 Old Epoch:2019-5-12 3:29:59 New Epoch:2019-5-12 8:36:9 newHour. 2019/05/12 08:36:09 Old Epoch:2019-5-12 3:29:59 New Epoch:2019-5-12 8:36:9 newHour. 2019/05/12 08:36:09 Created Xanbus Device: CSW ( 847509 ) 2019/05/12 08:36:06 SNTP:OK Server Time:Sun May 12 08:36:05 2019 RTC Time:Sun May 12 08:36:06 2019 2019/05/12 08:35:59 Old Epoch:2019-5-12 3:29:59 New Epoch:2019-5-12 8:35:58 newHour. 2019/05/12 08:35:59 System Startup - Application Version: Ver03.08BN0874 2019/05/12 08:35:59 Xanbus Bus Online 2019/05/12 08:35:59 Network Cable Connected 2019/05/12 08:35:58 Old Epoch:2019-5-12 3:29:59 New Epoch:2019-5-12 8:35:58 newHour.
Keeps repeating, mostly about "new hour":
2019/05/12 10:20:00 Old Epoch:2019-5-12 10:19:58 New Epoch:2019-5-12 10:20:0 new10mins. 2019/05/12 10:10:00 Old Epoch:2019-5-12 10:9:59 New Epoch:2019-5-12 10:10:0 new10mins. 2019/05/12 10:00:03 Reset odo: new hour 2019/05/12 10:00:01 Reset odo: new hour 2019/05/12 10:00:00 Old Epoch:2019-5-12 9:59:59 New Epoch:2019-5-12 10:0:0 new10mins. 2019/05/12 10:00:00 Old Epoch:2019-5-12 9:59:59 New Epoch:2019-5-12 10:0:0 newHour. 2019/05/12 09:50:01 Old Epoch:2019-5-12 9:49:59 New Epoch:2019-5-12 9:50:0 new10mins. 2019/05/12 09:40:01 Old Epoch:2019-5-12 9:39:59 New Epoch:2019-5-12 9:40:0 new10mins. 2019/05/12 09:30:32 Old Epoch:2019-5-12 9:29:59 New Epoch:2019-5-12 9:30:0 new10mins. 2019/05/12 09:20:00 Old Epoch:2019-5-12 9:19:59 New Epoch:2019-5-12 9:20:0 new10mins. 2019/05/12 09:10:01 Old Epoch:2019-5-12 9:9:59 New Epoch:2019-5-12 9:10:1 new10mins. 2019/05/12 09:00:05 Reset odo: new hour 2019/05/12 09:00:00 Old Epoch:2019-5-12 8:59:59 New Epoch:2019-5-12 9:0:0 new10mins. 2019/05/12 09:00:00 Old Epoch:2019-5-12 8:59:59 New Epoch:2019-5-12 9:0:0 newHour. 2019/05/12 09:00:00 Reset odo: new hour
I think the combox reboots at 3am daily ? Dave would know.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
It probably isn't doing anything bad, aside from filling up the event log. I don't know much about comboxes, but I'd; look for a toggle in (eg) custom logging menu to unset, or possibly if you've run any setup/update scripts lately (I think they're .lux files... plaintext?) check to see if it set the toggle.Off-grid.
Can't find a toggle, looked in several places but no luck. Have not done any updates or setups lately. If I can't find a solution to stop it I may just do a factory reset and start over with a clean slate.
You are overthinking this....
"Yes what Estragon said! Pretty normal. Started about 2 years back to fix and avoid issues. "
I agree with Dave... "fixing" this would be way, way down my to-do list.
It may something done in firmware a couple of years ago. If so it may mean reverting to older firmware, which could in turn open cans of worms best left closed.Off-grid.
It was the fix and done to avoid future issues. Moving combox to gateway is a much better and faster solution. The days are numbered for combox."we go where power lines don't" Sierra Nevada mountain area
So you are saying this has been going on and that I was just not aware? I actually found it by accident. Just weird that it seems to log something every 10 minutes. Thanks for the info, guess I will leave good enough alone.Just seeing it for the first time it looked like it started at 12 AM on 5/12 but now I see that it starts over every day at 12 AM.
- 234 Forum & Website
