Combox Log
stmar
stmar Solar Expert Posts: 370 ✭✭✭
Anybody seen something like this from their Combox log:
2019/05/12 03:10:00Old Epoch:2019-5-12 3:9:59 New Epoch:2019-5-12 3:10:0 new10mins.
2019/05/12 03:06:57Created Xanbus Device: SCP ( 1681104 )
2019/05/12 03:06:57SNTP:OK Server Time:Sun May 12 03:06:56 2019 RTC Time:Sun May 12 03:06:57 2019
2019/05/12 03:06:52Created Xanbus Device: CSW ( 847509 )
2019/05/12 03:06:49Network Cable Connected
2019/05/12 03:06:48System Startup - Application Version: Ver03.08BN0874
2019/05/12 03:06:48Xanbus Bus Online
2019/05/12 03:05:00System Reboot requested by reboot command - rebooting in 8 seconds
2019/05/12 03:00:03Reset odo: new hour
2019/05/12 03:00:01Old Epoch:2019-5-12 2:59:59 New Epoch:2019-5-12 3:0:0 new10mins.
2019/05/12 03:00:01Old Epoch:2019-5-12 2:59:59 New Epoch:2019-5-12 3:0:0 newHour.
2019/05/12 03:00:01Reset odo: new hour
2019/05/12 02:50:01Old Epoch:2019-5-12 2:49:59 New Epoch:2019-5-12 2:50:0 new10mins.
2019/05/12 02:40:00Old Epoch:2019-5-12 2:39:58 New Epoch:2019-5-12 2:40:0 new10mins.
2019/05/12 02:30:00Old Epoch:2019-5-12 2:29:58 New Epoch:2019-5-12 2:30:0 new10mins.
2019/05/12 02:20:00Old Epoch:2019-5-12 2:19:58 New Epoch:2019-5-12 2:20:0 new10mins.
2019/05/12 02:10:01Old Epoch:2019-5-12 2:9:59 New Epoch:2019-5-12 2:10:1 new10mins.
2019/05/12 02:00:03Reset odo: new hour
2019/05/12 02:00:00Old Epoch:2019-5-12 1:59:58 New Epoch:2019-5-12 2:0:0 new10mins.
2019/05/12 02:00:00Old Epoch:2019-5-12 1:59:58 New Epoch:2019-5-12 2:0:0 newHour.
2019/05/12 02:00:00Reset odo: new hour
2019/05/12 01:50:00Old Epoch:2019-5-12 1:49:58 New Epoch:2019-5-12 1:50:0 new10mins.
2019/05/12 01:40:00Old Epoch:2019-5-12 1:39:58 New Epoch:2019-5-12 1:40:0 new10mins.
2019/05/12 01:30:00Old Epoch:2019-5-12 1:29:58 New Epoch:2019-5-12 1:30:0 new10mins.
2019/05/12 01:20:01Old Epoch:2019-5-12 1:19:59 New Epoch:2019-5-12 1:20:1 new10mins.
2019/05/12 01:10:00Old Epoch:2019-5-12 1:9:59 New Epoch:2019-5-12 1:10:0 new10mins.
2019/05/12 01:00:03Reset odo: new hour
2019/05/12 01:00:00Old Epoch:2019-5-12 0:59:59 New Epoch:2019-5-12 1:0:0 new10mins.
2019/05/12 01:00:00Old Epoch:2019-5-12 0:59:59 New Epoch:2019-5-12 1:0:0 newHour.
2019/05/12 01:00:00Reset odo: new hour
2019/05/12 00:50:00Old Epoch:2019-5-12 0:49:59 New Epoch:2019-5-12 0:50:0 new10mins.
2019/05/12 00:40:00Old Epoch:2019-5-12 0:39:59 New Epoch:2019-5-12 0:40:0 new10mins.
2019/05/12 00:30:00Old Epoch:2019-5-12 0:29:59 New Epoch:2019-5-12 0:30:0 new10mins.
2019/05/12 00:20:00Old Epoch:2019-5-12 0:19:59 New Epoch:2019-5-12 0:20:0 new10mins.
2019/05/12 00:10:00Old Epoch:2019-5-12 0:9:59 New Epoch:2019-5-12 0:10:0 new10mins.
2019/05/12 00:00:06Reset odo: new hour
2019/05/12 00:00:06Reset odo: new day
2019/05/12 00:00:06Reset odo: new week
2019/05/12 00:00:02Reset odo: new day
2019/05/12 00:00:02Reset odo: new week
2019/05/12 00:00:01Old Epoch:2019-5-11 23:59:59 New Epoch:2019-5-12 0:0:0 newHour.
2019/05/12 00:00:01Old Epoch:2019-5-11 23:59:59 New Epoch:2019-5-12 0:0:0 newDay.
2019/05/12 00:00:01Old Epoch:2019-5-11 23:59:59 New Epoch:2019-5-12 0:0:0 newWeek.
2019/05/12 00:00:01Reset odo: new hour
2019/05/12 00:00:00Old Epoch:2019-5-11 23:59:59 New Epoch:2019-5-12 0:0:0 new10mins.
Just checked and it keeps repeating.
  • Estragon
    It sorta looks like debug output to me.  A program will often have an option invoked with debug switch (eg. myprog -d) for diagnostic purposes.  In this case, it looks like debug for writing/rolling logfiles.
    Dave Angelini Solar Expert Posts: 6,746 ✭✭✭✭✭✭
    Yes what Estragon said! Pretty normal. Started about 2 years back to fix and avoid issues.
  • stmar
    I heard something in the middle of the night, don't know if it was anything to do with the system, but when I checked it the Combox lights were going through their start up sequence. I logged in and found the above Events, no Warnings. At that point since it was 3 AM I disconnected the Combox and SCP. This morning reconnected and everything seems fine but still generating lines as earlier. Will let it run today and see what happens.
    2019/05/12 08:40:00Old Epoch:2019-5-12 8:39:59 New Epoch:2019-5-12 8:40:0 new10mins.
    2019/05/12 08:37:35Login: admin
    2019/05/12 08:36:10Created Xanbus Device: SCP ( 1681104 )
    2019/05/12 08:36:09Old Epoch:2019-5-12 3:29:59 New Epoch:2019-5-12 8:36:9 newHour.
    2019/05/12 08:36:09Created Xanbus Device: CSW ( 847509 )
    2019/05/12 08:36:06SNTP:OK Server Time:Sun May 12 08:36:05 2019 RTC Time:Sun May 12 08:36:06 2019
    2019/05/12 08:35:59Old Epoch:2019-5-12 3:29:59 New Epoch:2019-5-12 8:35:58 newHour.
    2019/05/12 08:35:59System Startup - Application Version: Ver03.08BN0874
    2019/05/12 08:35:59Xanbus Bus Online
    2019/05/12 08:35:59Network Cable Connected
    2019/05/12 08:35:58Old Epoch:2019-5-12 3:29:59 New Epoch:2019-5-12 8:35:58 newHour.
  • stmar
    Keeps repeating, mostly about "new hour":
    2019/05/12 10:20:00Old Epoch:2019-5-12 10:19:58 New Epoch:2019-5-12 10:20:0 new10mins.
    2019/05/12 10:10:00Old Epoch:2019-5-12 10:9:59 New Epoch:2019-5-12 10:10:0 new10mins.
    2019/05/12 10:00:03Reset odo: new hour
    2019/05/12 10:00:01Reset odo: new hour
    2019/05/12 10:00:00Old Epoch:2019-5-12 9:59:59 New Epoch:2019-5-12 10:0:0 new10mins.
    2019/05/12 10:00:00Old Epoch:2019-5-12 9:59:59 New Epoch:2019-5-12 10:0:0 newHour.
    2019/05/12 09:50:01Old Epoch:2019-5-12 9:49:59 New Epoch:2019-5-12 9:50:0 new10mins.
    2019/05/12 09:40:01Old Epoch:2019-5-12 9:39:59 New Epoch:2019-5-12 9:40:0 new10mins.
    2019/05/12 09:30:32Old Epoch:2019-5-12 9:29:59 New Epoch:2019-5-12 9:30:0 new10mins.
    2019/05/12 09:20:00Old Epoch:2019-5-12 9:19:59 New Epoch:2019-5-12 9:20:0 new10mins.
    2019/05/12 09:10:01Old Epoch:2019-5-12 9:9:59 New Epoch:2019-5-12 9:10:1 new10mins.
    2019/05/12 09:00:05Reset odo: new hour
    2019/05/12 09:00:00Old Epoch:2019-5-12 8:59:59 New Epoch:2019-5-12 9:0:0 new10mins.
    2019/05/12 09:00:00Old Epoch:2019-5-12 8:59:59 New Epoch:2019-5-12 9:0:0 newHour.
    2019/05/12 09:00:00Reset odo: new hour
    I think the combox reboots at 3am daily ?    Dave would know.
  • Estragon
    It probably isn't doing anything bad, aside from filling up the event log.  I don't know much about comboxes, but I'd; look for a toggle in (eg) custom logging menu to unset, or possibly if you've run any setup/update scripts lately (I think they're .lux files... plaintext?) check to see if it set the toggle.
  • stmar
    Can't find a toggle, looked in several places but no luck. Have not done any updates or setups lately. If I can't find a solution to stop it I may just do a factory reset and start over with a clean slate.
     You are overthinking this....
    "Yes what Estragon said! Pretty normal. Started about 2 years back to fix and avoid issues. "
  • Estragon
    I agree with Dave... "fixing" this would be way, way down my to-do list.
    It may something done in firmware a couple of years ago.  If so it may mean reverting to older firmware, which could in turn open cans of worms best left closed.
    It was the fix and done to avoid future issues. Moving combox to gateway is a much better and faster solution. The days are numbered for combox.
  • stmar
    edited May 2019 #12
    So you are saying this has been going on and that I was just not aware? I actually found it by accident. Just weird that it seems to log something every 10 minutes. Thanks for the info, guess I will leave good enough alone.
    Just seeing it for the first time it looked like it started at 12 AM on 5/12 but now I see that it starts over every day at 12 AM.
