best approach to connect 6 trojan 6 volts batterry
DarkstormNH
Registered Users Posts: 48 ✭✭
Folks if any of you have the best approach to connect 6 trojan 6 volts for 12 volts bank I'm looking for best approach to balance connect the bank using a dls-55 iota charger
please help
please help
http://www.smartgauge.co.uk/batt_con.html. This might help.
Look around their website for more good battery info.
Mine was three string of two 6 volt batteries in series. Then parallel to the inverter and controller. Now I'm 24 volts.
Thanks for the feedback I saw and visited this site many times, what is confusing is as I said I'm trying to setup 6 six volts batterylittleharbor2 said:http://www.smartgauge.co.uk/batt_con.html. This might help.
Look around their website for more good battery info. -
You need to create three, 12 volt batteries by series wiring two 6 volt batteries together, then treat them as three 12 volt batteries. like the picture except adding one more series pair.DarkstormNH said:
ok I'm getting there if I understand right you are going to a bus bar or a single point from there to the inverter, charger connect to the single point as welllittleharbor2 said:
Yes.
