best approach to connect 6 trojan 6 volts batterry
DarkstormNH
DarkstormNH Registered Users Posts: 48 ✭✭
Folks if any of you have the best approach to connect 6 trojan 6 volts for 12 volts bank  I'm looking for best approach to balance connect the bank using a dls-55 iota charger
please help
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,187 ✭✭✭✭✭
    edited April 2019 #2
    http://www.smartgauge.co.uk/batt_con.html. This might help.
    Look around their website for more good battery info.
  • billybob9
    billybob9 Registered Users Posts: 141 ✭✭
    Mine was three string of two 6 volt batteries in series. Then parallel to the inverter and controller. Now I'm 24 volts.
  • DarkstormNH
    Thanks for the feedback I saw  and visited this site many times, what is confusing is as I said I'm trying to setup 6 six volts battery
  • littleharbor2
    You need to create three, 12 volt batteries by series wiring two 6 volt batteries together, then treat them as three 12 volt batteries. like the picture except adding one more series pair.
  • DarkstormNH
    ok I'm getting there if I understand right you are going to a bus bar or a single point from there to the inverter, charger connect to the single point as well
  • littleharbor2
    Yes.
