best approach to connect 6 trojan 6 volts batterry
DarkstormNH
Registered Users Posts: 48 ✭✭
Folks if any of you have the best approach to connect 6 trojan 6 volts for 12 volts bank I'm looking for best approach to balance connect the bank using a dls-55 iota charger
please help
please help
http://www.smartgauge.co.uk/batt_con.html. This might help.
Look around their website for more good battery info.
Mine was three string of two 6 volt batteries in series. Then parallel to the inverter and controller. Now I'm 24 volts.
littleharbor2 said:http://www.smartgauge.co.uk/batt_con.html. This might help.
Look around their website for more good battery info. -
DarkstormNH said:littleharbor2 said:http://www.smartgauge.co.uk/batt_con.html. This might help.
littleharbor2 said:DarkstormNH said:littleharbor2 said:http://www.smartgauge.co.uk/batt_con.html. This might help.
Yes.
- 226 Forum & Website
- 618 Discussion Forums/Café
