Multiple charge controllers for one battery bank
I currently have one 330watt solar panel hooked up to a MPPT controller that is charging a 12V 300AH LifePo4 battery bank in my camper conversion. Would it be possible to connect a second MPPT charger controller to a second (smaller) solar panel and charge the same battery bank with both charge controllers efficiently?
Thank you
Multiple charge controllers on a bank is done often, and is generally not a problem.
One issue that can arise is when the controllers don't communicate (generally just the large, higher end ones do), they may get a bit out of step in charging. Typically, one sees a bit higher voltage than the other, but with a lithium bank and fairly conservative voltage, it shouldn't be an issue.
Be sure your battery preservation system (BMS) and charge controllers are all going to play well together, you don't want to cook anything
Larynx -
Our 19' Roadtrek has very limited real estate. Our son was able to get a 100 W and a 315 w panel installed. This required two controllers to the 4.5 kW-hr 12 V nominal battery suite. It has worked well on trip to Labrador (1000 km of fairly rough gravel) and Newfoundland and two trips to Yucatan. Battery suite is below bed with a blower that sends warm air from cabin to the battery box when temperature drops below 40 F (5 C). Scared the heck out of it the first time it did this at outside temp of 18 F (-8C). It never got above 85 F ambient in Yucatan.
We got leary of line power when we went up west coast of Mexico. Two RV sites in a row had very bad electricity: no ground. This resulted in shock when touching frame. So went just used solar the last four weeks of trip. We have since installed a ground cable to frame along with a thick copper rod pounded into earth. On beach of Yucatan, we put a pailful of sea water onto sand by rod.
Reed and Elaine
- 231 Forum & Website
