Honda generator question
Desert Rat
Desert Rat Solar Expert Posts: 147 ✭✭✭
A neighbor gave me a Honda EU2000i generator. In checking it out, I get 125 VAC with my voltmeter when connected to the HOT and NEUTRAL of the receptacle. But only 62.5 VAC when connected to HOT and GROUND. What gives?
  • Desert Rat
    OK, I realized that Neutral and Ground are not bonded in this generator. Did I answer my own question?
    BB. Super Moderators, Administrators Posts: 33,734 admin
    Yes
  • Wheelman55
    Wheelman55 Registered Users Posts: 277 ✭✭✭
    Mr Rat. Both of the cords on my two EU2000i’s broke within three days of each other last week. I replaced them with these Kevlar cords:
    You need to take ALL of the covers off to replace. The second one only took an hour and a half...the first took a bit longer. Google’s your friend here :)
    PS. Mel and I did the drive up to the top of the Christmas Mtn’s this morning...beautiful.
    Best. PP.
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
