Generator on the fritz
Allright, the concert ticket and a halter top at the beach....My 64 GTO that I lent a guy, and spent a month working on the limited slip.
Good news so far. Brushes were quite worn. One had frayed wire riding next to the slip ring. Gen started right up. Will check voltage tomorrow to see if voltage regulator needs replacing.
Off-grid 48v, 3 kw PV, Sunny Island 5048U, SunnyBoy, US Battery RE L16XC 6v, 800ah, Genset: Kohler 8.5 RES propane. -
First question in my mind is--
Is the genny being shut down because of low voltage, or is it shutting down causing a low voltage fault?
Easy enough to check and I suppose it has been.
3310 watts panels, Classic 200 controller, 8 Surette S530's, Xantrex 5548 inverter, Honda EX5500 backup Genny. -
Original problem was occasional shut down, charge controller showed low voltage fault. I checked connections,etc.
Then a few weeks later, gen would crank up, begin to run for a split second then immediately shut down with an under voltage fault showing on the genset.
Brushes changed, now all good. No need for change on voltage regulator.
Not sure I know the answer to your question...I think originally the charge controller shut down the gen for low V. Then the gen began shutting itself down.
Some say those brushes look older than 850 hrs, I'll just have to change them again in another 700.
Good to hear it was a simple and hopefully inexpensive fix.
I am using an Onan Emerald 4.0 that was removed from a motorhome, quiet, 1800 rpm always runs, 2 changes of brushes, 3 oil changes , points , 4 spark plugs, 5 years no fail to run... burns more gas than inverter gen but has a beautiful clean sine wave output, tremendous overload capability......only change from motorhome use...its own house and a Stewart Warner engine minder.......automatic shutdown on fault...lol oil....hi temp.@.oil and cyl heads, and exhaust temp. Cummings builds great generators $$$$$$. 16 hp engine with 3 1/2 quarts oil and spin on filter...same filter as Toyota cars. Real long life machines2 Classic 150, 2 Kid, 5 arrays 7.5 kw total 2ea. 2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200, 2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100, 2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4,
