12 volt battery, natural gas charged. Natural gas range and fridge
DJudell
DJudell Registered Users Posts: 7 ✭✭
I have a cabin. No electricity. I have unlimited natural gas. I want to have a gas range and fridge and run lights,tv on 12 volts. I am unsure about heat. I thought there would be a simple natural gas charging system but maybe I am reading too much. I basically did this 40 years ago with propane. Batteries don't seem to have changed much. My biggest change is that I don't want to burn wood for heat. Any suggestions are appreciated. Thanks. I am new to the group and I hope this gets posted. No surprise I do not have a smart phone and use computers very little. Doug Judell
  • jonr
    edited March 2019 #2
    I'd consider a Honda Eu2200i with a natural gas conversion kit. With Lithium batteries (which can charge quite quickly). Add solar panels if you want.
    A direct vent wall heater will produce heat with no electricity.
    Welcome to the forum DJ,
    There are "fuel cells" which sound ideal... They are built like batteries with plates in a box. But you introduce hydrogen and oxygen and the "low temperature" burning produces electricitiy. HOWEVER, they generally only work with very clean hydrogen gas (need a reactor to create hydrogen from natural gas, and the plates are made with expensive metals like platinum or palladium (as I recall). If you have a bunch of money sitting around you will never otherwise need ($100k's ???), it can be done.
    Another very low power system is a TEG or Thermal Electric Generator system. Basically flame from your natural gas heats thermal couples to generate power. Not too expensive, no moving parts, relatively low efficiency ("free gas"), and reliable (i.e., 125 watts * 24 hours per day = 3,000 WH per day--Just about enough to run a near-normal electric lifestyle with Energy Star Fridge, LED lightning, laptop computer, RV water pump or solar friendly well pump, clothes washer, etc.) :
    https://www.tegmart.com/info/guide-to-understanding-and-using-teg-power-and-products/
    If your energy usage is low, you can use this to charge a small battery bank and run your loads.
    And as Jonr suggests, another option is a natural gas fired genset. This can be done with a spark ignition engine, or you can feed natural gas into a diesel engine (still need diesel to start/run the engine, but natural gas can replace much of the diesel fuel used). The propane/natural gas conversion is probably the easiest/cheapest/most common solution. You probably need to "filter" your natural gas (is this "wet gas" directly from a well?). Natural gas has less "heat energy" vs gasoline in an engine, so you generally have to derate the generator output by 20% or so (as I recall) from name plate rating.
    https://duckduckgo.com/?q=natural+gas+conversion+for+generators&atb=v122-1__&ia=web
    I assume that you have an RV or Trailer parked on property with a well? So, really a fixed installation and not an RV where you can pipe into a gas meter on trips...
  • DJudell
    I will look at TEG. I have wondered if I want a natural gas fridge or not. I have a cabin, not an RV. My first thought was a natural gas genset. I also [kind of] hoped for an answer like "the only thing in your position is to....". Thank you for your input.
  • 706jim
    706jim Solar Expert Posts: 527 ✭✭✭✭
    If you can generate enough electricity, I'd stay away from the gas fridge. They don't defrost and will always carbon up to some degree. Guessing you have your own reasons for not heating with wood (yup, it's messy).
    Let us know how things work out.
    Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
  • DJudell
    I might even rethink heating with wood. I did it for 10 years at the cabin but I was much younger. I also used kerosene lights but I don't think I would ever go back to those. I have to see if I can generate enough electricity to have an electric fridge.
    Doug,
    I have moved your thread to the general Off Grid systems forum. (I missed that you are in a cabin in your first post).
    Propane (and natural gas?) refrigerators tend to have issues with needing good ventilation and cleaning (every 6-12 months if you get soot buildup). And can create a carbon monoxide/humidity issue if you do not ventilate outside in a well insulated cabin in a cold climate.
    Collecting data (how much energy per day in Watt*Hours or Amp*Hours*Volts, possibly by season), where you are (good solar or poor with lots of trees/shading--Solar electric needs clear sky for most of the day).
    Solar heating (hot water, etc.), can be pretty neat--But you almost have to like plumbing (valves, pumps, thermal panels, etc.)--If you get enough sun in the winter. Climates with hard freezes gets a bit more complex (anti-freeze, drain back systems, etc.).
    If you are full time off grid, and can swing a solar electric system (call it ~3,300 Watt*Hours per day), you can usually run a full size refridgerator (and get frost free, good cold and freezer sections).
    If you are interested in "low power" electric... A 7-10 cuft chest freezer with a refrigerator "range" thermostat can cut you from 1.0 to 1.5 kWH per day for a very good upright energy star fridge/freezer to a ~250 Watt*Hour (0.25 kWH) per day refrigerator only.
    You are correct that Batteries (Lead Acid and variations like AGM) have not really changed much in 40 years, other than getting somewhat more expensive.
    There are new tech like various Li Ion batteries (LiFePO4 -- Lithium Iron Phosphate) which are getting popular (pretty safe, stable, long life--But do not like sub freezing conditions for charging/discharging). But, there is complexity--Possibly needing a BMS (battery management system) to balance/protect each cell against over/under voltage. A bit cutting edge, and not cheap--But gaining more users over time.
    Solar Electric Panels, that is where the off grid energy advancements have come... From 8% efficiency to 15%+ efficiency, and dropping from $10-$40 per Watt to under $1 per Watt (if you shop around). And from 10-100 Watt panels to 200-300 Watt panels (fewer panels, less issues with wiring and mounting--But >~175 panels, you usually need 2 people to move and install).
    And MPPT (Maximum Power Point) solar charge controllers... Can (for example) take an array voltage (Vmp--Voltage Maximum Power) of ~20-100 VDC standard test conditions) and efficiently down converter to charging your 12 volt battery bank. The US made/designed MPPT charge controllers are not cheap ($500 to $600 for higher end 80+ amp units), but now have Internet servers (for remote management) and lots of programmable charge settings, and some optional outputs (like using a "dump" load for water pumping when the batteries are full, etc.).
    Details matter (amount of power you need, where the system will be installed, shading issues, 120 VAC vs 12/24/48 VDC, what kind of batteries do yo want, etc.).
    Even with "free fuel" for your genset--I would highly suggest that a moderate solar array and good quality charge controller and a bunch of lead acid golf cart batteries or larger flooded lead acid batteries (~650 AH @ 24 volts will support 3,300 WH quite nicely). With ~10% rate of charge (don't know where you are at, so cannot work out hours of sun):
    • 650 AH @ 29 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 2,448 Watt array @ 10% rate of charge
    Would probably give you enough energy that you could run 9+ months a year on solar+battery bank, and during winter, only run the genset during "bad weather" and/or poor solar harvest conditions.
    If you don't use a full size energy star rated refrigerator, and go with propane/natural gas... You could probably get down to ~1,000 WH per day quite nicely (LED Lighting, RV Water pump, Laptop computer, LED TV, cell phone charging. And with the smaller loads, I would not even bother with a genset except for bad weather. Avoid the noise and oil changes vs running the genset as your only source of electricity.
  • DJudell
    I will reread and study. My cabin is in the woods in Western New York State. At one point I thought that my area got the least days of sunshine anywhere. That might have been for the winter months. We certainly have a lot of gray days. I have been leaning towards golf cart batteries. My biggest concern is charging them. I would want very little power from them, enough for a tv and lights. I don't even plan for a laptop. I would want to charge my cellphone. I guess I would want a water pump if I ever added running water. Another question [for another time] is that I'm hoping that I can in some way store music in the "cloud". I am only thinking about being there for 8 months a year. I don't need any more WNY winters. I am living in Wisconsin now. I could learn to clean the refrigerator, maybe it would be best to use a gas fridge and then my battery use would be minimal. In the 70's I had a couple of trolling batteries that I carried around,got charged in town or swapped out in my car. I have cleared the trees around the cabin, maybe solar could work? I am very glad that I asked the question on this forum. Once I start making mistakes I am sure that there are people who can tell me what I did wrong.
    You really need good sun from around 9am to 3pm at least.
    Take a look at this website for how much sun you will get. Fixed array, facing south, tilted for best harvest year round:
    The new editor software does not let us post tables (hope to fix soon). But if you are there from March through October, you get 3.29 (March) to 2.73 (October) hours of sun (long term average per day).
    Say you start with a gas fridge... 1,000 WH per day is a good start for a cabin (LED lighting, reasonable size LED TV, RV water pump, cell phone).
    You should get a Kill-a-Watt type meter to measure your AC loads to be sure (i.e., 30 Watt TV * 5 hours a day = 150 WH, cell phone ~10 WH per day, LEDs 18 watts * 5 hours = 90 WH per day etc.) and add it all up.
    Say 1,000 WH per day is good, and during bad weather, you can cut back on power usage and/or start up a genset every 2 days if needed.
    • 1,000 WH per day * 1/0.85 AC inverter eff * 1/12 volt battery bank * 2 days storage * 1/0.50 max discharge = 392 AH @ 12 volts
    Or 4x 200 AH @ 6 volt golf cart batteries--2x in series (for 12 volts) and 2x parallel strings (for 400 AH).
    Charging with solar, suggest 5% to 13% is a good range. 10%+ recommended for full time off grid:
    • 400 AH * 14.5 volts charging * 1/0.77 solar panel eff * 0.05 rate of charge = 377 Watt array minimum
    • 400 AH * 14.5 volts charging * 1/0.77 solar panel eff * 0.10 rate of charge = 753 Watt array nominal
    • 400 AH * 14.5 volts charging * 1/0.77 solar panel eff * 0.13 rate of charge = 979 Watt array "cost effective" maximum
    And then based on hours of sun per day... Say October at 2.73 hours of sun (break even month--probably need some generator time):
    • 1,000 WH per day * 1/0.52 off grid AC system eff * 1/2.73 hours of sun per day = 704 Watt array October "break even"
    You should never plan on using 100% of predicted power from a solar system... So the amount of array "oversizing" depends on your needs (closer to 1,000 or 500 WH per day, running genset near winter OK, or larger array to cut genset runtime--your choice).
    Solar panels are pretty cheap these days, and over sizing the array can keep your batteries "happier" longer (undercharging/over discharging is not good for them).
    If you ignore March and October (questionable weather months), the rest of the season you are >4 hours of sun per day, which when paired with a 753 Watt (10% rate of charge) array, will give you:
    • 753 Watt array * 0.52 AC system eff * 4.0 hours of sun = 1,566 Watt*Hour per day average
    Not a bad harvest for New York.
    I would suggest adding a ~300 Watt TSW AC inverter with 12 VDC input--Such as the MorningStar unit--Has remote on/off switch and standby mode (low power search mode, when >8 Watts is detected, the inverter turns on 100% to power loads). Or similar:
    https://www.solar-electric.com/kiacpomome.html (kill-a-watt meter)
    https://www.solar-electric.com/morningstar-si-300-115v-ul-inverter.html (MorningStar 300 Watt inverter)
    https://www.solar-electric.com/sa300wa12vos.html (Samlex 300 Watt TSW inverter)
    Add a >=40 amp MPPT charge controller (or slighting larger PWM controller--depends on what solar array you design), and you have your basic system (+ panel racking, wiring, grounding, circuit breakers, outlets, and a few tools like a voltmeter and hydrometer).
    This is what I think would meet your needs. Run for a few years then decide if you need more power or not.
    Just be aware, it is not easy to expand a solar power system by a lot without needing new hardware (12 vs 24 volt battery bank for larger inverter, larger charge controller, new batteries usually, larger array, etc.).
  • DJudell
    Thanks you very much. I wonder about staying away from an inverter. I remember well blowing up my first [only] one. Who knew there were square waves and sine waves? An inverter does sound like it could be added at a later date without changing the system. How close to the cabin does it have to be so I don't have to move the charged batteries? I remember that direct current has some limits. I think that my best sun would be at least 100 feet from the cabin. I could certainly figure out how to get the charged batteries next to the cabin but it would be nice not to move them.
    In general, is not AC vs DC that is the problem with longer wire runs, it is low voltage/high current that is difficult to send long distances.
    For example, 10 amps * 12 volts = 120 Watts, and so does 1 amps * 120 Volts.
    With 12 volts, you can have about 0.5 volts of voltage drop in your wiring. With 120 VAC, you can have 3% or 3.6 volts of drop at 1/10th the current (V=I*R). So need much less copper (lighter wiring) to send the same amount of power for a long distance.
    Playing with a voltage drop calculator, say you want to send 120 Watts 50 feet. Using a simple voltage drop calculator (50 feet, 10 amp & 12 volts vs 1 amp and 120 volts):
    https://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=1.296&voltage=12&phase=dc&noofconductor=1&distance=50&distanceunit=feet&amperes=10&x=64&y=29
    6 AWG carrying 10 amps @ 12 VDC:
    Voltage drop: 0.40
    Voltage drop percentage: 3.29%
    Voltage at the end: 11.6
    https://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=84.22&voltage=120&phase=ac&noofconductor=1&distance=50&distanceunit=feet&amperes=1&x=64&y=18
    24 AWG carrying 1 amp @ 120 VAC:
    Voltage drop: 2.57
    Voltage drop percentage: 2.14%
    Voltage at the end: 117.43
    That is, roughly 6x heavier copper wire for same 120 Watts at 12 vdc vs 120 vdc (roughly, every 3 AWG change in gauge is 2x or 1/2x the cross sectional area of the wire).
    Of course, you would not use 24 AWG wire to carry 120 VAC (14 AWG is generally the smallest diameter you would use for house wiring).
    Loss in efficiency of using an inverter of 85% (typical inverter), can be made up by making your solar array and battery bank 1/0.85=1.18x larger ... or ~18% larger. Generally, the costs of sending DC anything more than 10-20 feet from your battery bank (heavier wiring, larger fuses/breakers, non-standard DC "power plugs" other than "cigarette lighter" style), it just becomes an expensive method to distribute low voltage DC power.
    There are secondary issues--Such as 12 volts and above, DC sustains Arcs better than AC voltage/current. So you need switches and fuses/breakers rated for DC. And many "12 volt" DC loads don't "like" the 10.5 to 15-16 VDC that a deep cycle battery bank "bus voltage" runs at. It has been known to "kill" 12 VDC adapters for laptop computers and such (which seem to be designed for roughly 12.0 to 14.4 (typical automotive battery voltage range).
    For example, you design one/short heavy power connection for the AC inverter (designed to run 10.5 to 15-16 VDC). A 300 Watt @ 12 volt branch circuit would be:
    • 300 Watts * 1/0.85 inverter eff * 1.25 NEC derating * 1/10.5 battery cutoff voltage = 42 amps ~ 50 Amp 12 volt DC branch circuit wiring+breaker that is only a few feet long
    A good quality AC inverter should last 5-10+ years.
    But, yes, extra costs, extra things to go wrong. Longer term, generally worth the hassles and expense.
    Regarding sending power 100 feet from "sunny area" on your property to the cabin. In general, you have two ways of doing this. One is to put the solar+battery shed in the sunny area and send 120 VAC back to the cabin. This sort of becomes a pain, in that you have to trek 100 feet when you need to do maintenance and monitor your battery bank.
    Or, you install the solar array 100 feet away, and set it up with higher Vmp-array of say 90 VDC and use a (not cheap) MPPT solar charge controller. The controller can take high voltage/low current and efficiently (~95%) from 90 VDC at 6 amps to ~14.5 volts at 37 amps.
    3x solar panels at 250 watt per panel at Vmp~30 volts would be nice with a higher end 40-60 amp MPPT charge controller:
    https://www.solar-electric.com/mnclassic.html
    https://www.solar-electric.com/motr45ampmps.html
    The first link is a "high end" MPPT charge controller (96 amp output @ 12 volts) with Ethernet/Internet server/connection support.
    The second is 45 amps max output, no internet connection, and no fans--Fans can be noisy and if the controller is mounted inside the cabin, can be irritating (during the day when the sun is up).
    Just two choices linked. There is a lot out there, including some pretty inexpensive stuff from China/Overseas (variable quality).
    To send 750 Watts 100' at 90 VDC (~100 Vmp maximum for cold climates with a 150 VDC max input controller) would require wiring of:
    • 750 Watts * 1/90 volts (3x panels in series with Vmp~30 volts each) = 8.33 amps Vmp-array
    Using 8.33 amps and 1% to 3% voltage drop (typical wire loss design for solar) and voltage drop calculator (8.33 amps and 100 feet):
    8 AWG, 100 feet, 8.33 amps:
    Voltage drop: 1.05
    Voltage drop percentage: 1.16%
    Voltage at the end: 88.95
    And the minimum suggested AWG:
    https://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=5.211&voltage=90&phase=dc&noofconductor=1&distance=100&distanceunit=feet&amperes=8.33&x=56&y=21
    12 AWG, 100 feet, 8.33 drop
    Voltage drop: 2.65
    Voltage drop percentage: 2.94%
    Voltage at the end: 87.35
    2x X AWG cabling (your wallet) from array plus a 6 AWG (minimum) grounding conductor from Array frame/ground rod to Cabin ground rod (for electrical safety and lightning protection).
    I suggest that you do not put the batteries inside the cabin (charging gasses and sulphur fumes). Outside insulated shed/ground contact to keep batteries from roughly 40-80F, ideally). Suggest that genset+fuel in separate structure away from cabin/battery bank to reduce chance of genst fire (or battery+wiring fire) from taking "everything" out) in one incident.
    I will stop typing here. Still lots of details to workout/understand for your needs. But you can start a paper and pencil designing and see where it takes you for your needs.
  • NANOcontrol
    NANOcontrol Registered Users Posts: 280 ✭✭✭
    I had a RV stove and oven combo. The three burners were to tight to use much more than one at a time, maybe two. I got a nice gas stove and converted the range top to work with 12V. Maybe this year I'll get the oven to work. It uses a glow bar that runs all the time and uses 400W. So how is that a gas oven? I got a plan to run it up to temp and just shut off after lit. Should work for what I cook. Investigate that before purchasing a stove. I am also upstate NY. 8 months is longer than I want to spend there with no heat. I hate batteries and just bring a car battery out of a vehicle I don't bring with me. I still live better than most. Have PV hot water, chest fridge and even a dishwasher with heated dry. Batteries are a looooooser and it can almost be done without them. Are you getting your own gas out of the ground? I know it is in that area. I'd be in hog heaven.
  • DJudell
    I am getting gas from a well. I don't want to overthink this. I see some problems with gas refrigerators but I consider that I need a refrigerator for a kitchen. I think I might get a direct vent wall heater. I still have my old Ashley there and I might use that in the morning. I do see where an inverter makes sense, lots of things like a blender could just be plugged in. I have not used batteries much. I am hoping that they are user friendly. I would like to keep things as simple as possible. I hope to get there this spring and get some plans on paper.
    Batteries are not user friendly... If you design a system "conservatively", it helps keep the batteries happy. Checking voltage, specific gravity (if flooded cell), and just watching for something that looks "different". Most folks probably "murder" their first battery bank.
    Forgetting to turn off "ALL LOADS" during winter when nobody is there (solar charging, or a small float charger is helpful). Or friends/kids use the place while you are elsewhere--Plug in everything, leave everything on, and drain the battery bank dead in a couple days (usually taking a rechargeable battery "dead" -- near zero state of charge -- kills the battery bank).
    I am not off grid, but if you spend 15 minutes a week just double checking voltages and specific gravity, and keeping the batteries clean (wipe up spills, keep cables/connections from corroding, etc.)--It should not be a big deal.
    Genset maintenance and oil changes are similar.
    Solar is great for a place you use many months of the year. Use a small solar system for your "quiet time" energy usage. And fire up the genset to run tools, recharge the battery bank after two days of bad weather, etc.
    Best wishes,
  • DJudell
    I am optimistic. I am anxious to get going but I don't know when I can. Over the years I have learned to do a few things and I think I could [might] keep a battery bank alive.
    Doing your research first is a good start.
    Bill
  • Ronwilliam
    Ronwilliam Registered Users Posts: 1
    Unlikely setup, natural gas appliances need constant supply, not batteries.
  • JRHill
    JRHill Registered Users Posts: 509 ✭✭✭✭
    Please explain further, Ron.
    Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
