Battery storage confusion
Okay, I'm quite new to solar power and love dealing with electricity, as well as pc/computer systems. so I was going to try and test a few things, I know how solar panels work, the converter/inverter and all the other gadgets to actually use one. one thing I'm not understanding is battery storage so i was looking to power a 1500 watt machine (ASIC to be exact, that runs on a 240v ac) while the sun is not out. so i was looking at the "Rolls Surrette S-1660 Flooded Battery 1284Ah 2V" where the amps/watts would be fine. one thing i do not understand about this is that it says "2v" does that mean ill have to have 120 of these batteries to power a single 240v ac plug? or am im missing a conversion between dc to the ac plug
You put together a DC battery based system, using of either 12v, 24v or 48v. Most likely 48v for you.
That would mean 24 of the 2v batteries to make a 48v DC system. The inverter changes the DC to AC
There’s more to it than this. The experts here will guide you through.
Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries -
The inverter will convert the 48V DC, into 240VAC (if you buy a 240VAC inverter instead of a 120VAC )
