Solar Sculpture help
Db1966
Registered Users Posts: 3 ✭
I'm working on a metal sculpture that includes an old fashioned street light. My plan is to convert it into a solar LED street light. I've chosen a 50 watt corn LED that will screw into a standard light socket. Below the light is a bench, on the bench sits a large metal robot. Inside the robot will be a flame LED (4 watt) and two blue candelabra c7 bulbs (.5 watt each). All LEDS will turn on at dusk and run off battery power and turn off at dawn, battery recharges.
My questions...
What sized battery is recommended? 6V or 12V? I'm thinking a Lithium Ion...thoughts?
Do I need a 12v to 110v power converter to go from the the battery to the LED's or will the charge controller handle that job?
Any recommendation on a charge controller would be helpful as well.
And lastly, what sized solar panel can I use that will mount on top of the street that will be small but charge the battery enough?
Thank so much to anyone that can point me in the right direction.
My questions...
Welcome to the forum DB.
Working with solar power, you need to be as conservation minded as possible. And with lighting, the way our eyes work, a 50 Watt vs 25 Watt (otherwise identical LED lamp) is almost impossible to see the difference. So, you may be able to reduce the power usage by a factor of 2 right there.
Some of the more modern LED lights run at low power (1/3 to 1/10 of full power?) and when a motion sensor is tripped, the light goes to full power--Another method to save energy.
https://www.allelectronics.com/category/340100/leds/standard-5mm-t-1-3/4/1.html
With LEDs, color temperature and LED design can dramatically affect the apparent lighting intensity. Corn Cob lamps--I am not sure that they are in the top tier of efficiency... And many of the cheap corn cob lamps are driven to fairly high levels (fewer LEDs at with more power--save money on LEDs) and "cheap LEDs" (like T 1 3/4) have very poor heat dissipation (LEDs and phosphers get hot and turn dark in a few hundred hours) vs some of the newer surface mount LEDs with heat sinks (some folks even use copper heatsinks).
Lastly, there is the efficiency of the LED driver circuit.... LEDs are low voltage (typically around 2-5 volts) but they need a circuit to control the amount of current flow through them. Cheaper installations simply may use a resistor. More expensive (and more efficient/stable switch mode current sources) circuits can be much more efficient.
The Candle Power Forums is an interesting place to look around. LEDs and driver circuits. Directed mostly towards flashlights, but lots of low power/high lumens/etc. LED and small battery discussions.
https://www.candlepowerforums.com/vb/forum.php
My suggestion is to get a bunch of different LEDs and driver circuits. Experiment to get the effects you need. Then use something like a Doctor Watson DC Amp*Hour/Watt*Hour meter to measure you usage (lots of new meters out there today).
https://www.rc-electronics-usa.com/ammeters/r102-amp-hour-specs.html
And figure out how much energy you need (Watt*Hours per day, Amp*Hours at XX Volts per day, etc.). And design a system that will support it.
On the other side, you can estimate how much energy you can generate with solar... For example, say the largest solar panel you can mount is a 20 Watt panel. And you will be installing near Phoenix AZ with fixed solar array:
http://solarelectricityhandbook.com/solar-irradiance.htmlPhoenix
Measured in kWh/m2/day onto a solar panel set at a 57° angle from vertical (added. -BB):
And you design a system that turns of the LEDs if the battery is discharged. The amount of energy you can harvest would be (long term average) for January would be:Jan Feb Mar Apr May Jun 4.92
5.55
6.45
6.83
6.74
6.57
Jul Aug Sep Oct Nov Dec 6.08
5.78
6.03
5.82
5.24
4.74
- 20 Watt panel * 0.61 DC off grid system eff * 4.92 hours of sun (ave January day) = 60 WH per day
- 60 WH per day / 12 volt battery bus = 5 Amp*Hours per day
- 60 Watt*Hour per day / 10 hours = 6 Watt average load.
Bill thank you so much for all of that information! Seems like I need to rethink my system a bit before I go any further. And here I thought I could simply hook up some leds to a battery and be good.
Look towards 12V LED lights, keep wattage low, 50 w is a significant load which would require a fairly large battery to power overnight, <10W ~6000K (daylight ) LED 's provide impressive lumen output, they are commonly available at 12V https://www.amazon.com/ChiChinLighting-voltage-Halogen-Equivalent-System/dp/B01CU0OAHQ/ref=sr_1_2_sspa?ie=UTF8&qid=1549076901&sr=8-2-spons&keywords=12v+led+bulb+6000k&psc=1 . Once lamps are selected then sizing of their needs can be addressed, remembering keeping wattage low will reduce the overall costs, staying with 12V further reduces cost as no inverter is required.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
You are very welcome DB.
Setting your expectations is a good start.
Yes LEDs and batteries are a good start... But if you plan on changing the batteries out every 7 days (take back to the shop and recharge), that is different then "letting the sun" recharge them for you--And planning on your energy budget, etc.
And you have to look at the "real specifications" / actually do the measurements.... A "50 LED bulb" may take 50 Watts, or it may take 9 watts and be the "equivalent Lumens" of a standard filament bulb.
If it is a true 50 Watt bulb, a 20 Watt panel will only support 50 Watt*Hours per day:- 60 WH per day available energy / 50 Watt load = 1.2 hours nominal in January with a 20 Watt panel.
Sounds like I need to get rid of the 50w, thats easy as it was only on the list and not purchased. And the street light I'm using won't be used as an actual street light in the sense that it's being used more 'artistically' so it doesn't need to be as bright as a regular street light. I'll look into the <10W 6000K
Look for LED lighting with warm white light color. The cool white can be harsh and in the bluish color range. Here's a retro Edison style Led bulb in warm white, found on eBay.
is your lighting running 120VAC or 12VDC ?
If you need 120VAC, look at the small but efficiet Suresine 300w inverter from MorningStar solar. it's not cheap, but rock solid. And if you have long cable runs, you have to go with 120VAC to reduce losses in the long lines.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
