Additional Panel
kampf2000
Registered Users Posts: 4 ✭
I want to add a fourth panel to a 3 panel set of 17.5 volt 100 watt panels. I can't find a compatible 17.5v panel. Best I can find is a 18v +/-.3v 100 watt panel. Is this close enough to add to the set?
The voltage is close enough, just make sure the controller can accept the total VOC of 4 in series.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Sets are wired in series. I plan to add 1 of the new panels to each set of three for 2 sets of 80v +/- each.
Most controllers should be ok with that voltage, but it would be a good idea to check the manual for maximum string voltage into the controller to be certain. If it's close (~100v or less) and your climate can get cold, adjust the string voltage (Voc, not Vmp) up to adjust for record low temp in your location.Off-grid.
Is there any way of testing for maximum string voltage if you don't have the manual?
Look it up online. Testing? Not unless you don't mind smoking the controller when you find/excede that maximum voltage.
DenverB said:Is there any way of testing for maximum string voltage if you don't have the manual?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
