Additional Panel
kampf2000
kampf2000 Registered Users Posts: 4
I want to add a fourth panel to a 3 panel set of 17.5 volt 100 watt panels.  I can't find a compatible 17.5v panel.  Best I can find is a 18v +/-.3v 100 watt panel.  Is this close enough to add to the set?
  • mcgivor
    The voltage is close enough, just make sure the controller can accept the total VOC of 4 in series.
  • kampf2000
    Sets are wired in series.  I plan to add 1 of the new panels to each set of three for 2 sets of 80v +/- each.
  • Estragon
    Most controllers should be ok with that voltage, but it would be a good idea to check the manual for maximum string voltage into the controller to be certain.  If it's close (~100v or less) and your climate can get cold, adjust the string voltage (Voc, not Vmp) up to adjust for record low temp in your location.
    Off-grid.
  • DenverB
    DenverB Registered Users, Users Awaiting Email Confirmation Posts: 1
    Is there any way of testing for maximum string voltage if you don't have the manual?
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,196 ✭✭✭✭✭
    Look it up online.  Testing? Not unless you don't mind smoking the controller when you find/excede that maximum voltage.
  • mcgivor
    Depending on the manufacturer, some offer string calculators which are helpful in determining the maximum voltage, short of that, a voltage measurement with a digital voltmeter in the coolest temperatures under full sun is about the closest one could get. There is a certain amount of of headroom with some quality controllers, but a generic controller, who knows. Generally it's best not to push the limitations, just to be on the safe side of things.
