Practical maximum charge current vs PV array Isc
kevinhjones
Registered Users Posts: 1 ✭
I have an array that produces 90 amps short circuit (Isc) during maximum light conditions. As a
rule of thumb, what would be the most current I could expect to be able
to be delivered to the battery bank that is discharged to 50% charge? I
am assuming that it would be somewhat less when actually delivering
current through the bank.
The array is made
up of varied panels and are old, and I don't have access to PV curves,
but I would just like to just get some ballpark idea of roughly what
percentage of Isc can actually be forced through an average bank.
The amps delivered varys according to the battery internal resistance. AGM will, under same conditions, will recharge much faster than FLA because they have 1/10 of the internal resistance. That last 10% of charge still takes a long time.
The forcing part depends on the voltage you set, 14V will be much slower than 18VPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Use Imp as the maximum charging current... You may get a little more, but not much. Isc is driving into a dead short. Imp is driving into a optimum load voltage (like ~18 volts Vmp for a "12 volt" panel).
It does also depend on the type of solar charge controller. PWM charge controllers pass (pretty much) Imp-array current.
For an MPPT type charge controller, it is a bit more complicated, but it is the power of the array (actual wattage), then Ibatt=Parray/Vbatt.
