Solar Isolation Chart
hemmjo
Solar Expert Posts: 94 ✭✭
Back when I began assembling the solar electrical systems listed in my signature, I had found a web site that clearly showed Solar Isolation for various cities around the world. Specifically it had cities in the Dominican Republic. It made very clear the sun available on various days of the year at various times of the day. It was so complete, showing dates, sun angles, and times for dawn, dusk, sunrise, sunset with graphics. It was a great resource for explaining to people some of the limits of solar power generation.
I am now trying to educate someone else in the operation of these systems. I cannot find this great resource now.
Any help would be appreciated.
John
Two systems in the Dominican Republic http://villagemountainmission.org/
installed Feb 2014 at 19.796189° -70.893594°, Classic 150 + WBJR, KISAE SW1210, MN Battery Monitor, IOTA DLS 55/IQ4, 4- Solar World 275w, 4-6v x 225ah Trace Batteries
installed Feb 2015 at 19.795733° -70.893372°, same components as above
Honda PowerMate PC0497000, 7000/8750w generator - powers the well and chargers maybe once a week
This link contains valuable educational information https://www.pveducation.org/pvcdrom/properties-of-sunlight/calculation-of-solar-insolation
Another useful site http://solarelectricityhandbook.com/solar-irradiance.html
You mean Insolation. Here are a few of my saved bookmarks, saved for just this type of occasion.
http://solarinsolation.org/
https://www2.pvlighthouse.com.au/calculators/solar path calculator/solar path calculator.aspx
http://solarpaneltilt.com/
Linked to https://www.gaisma.com/en/Sorry for the delayed response. Signed up for the forum same day you posted question, took awhile to be approved.Hope this info helps,
Scott
Houseboat - 1 ReneSola 250W PV, 3 12V 115Ah parallel FLA Store Label (Excide), KID w/WBJR & Shunt, BigBabyBox 3 breakers; 60A (switch) Bat-Bank to House, 30A PV In, & 30A KID to Bat-Bank), 1 Aft & 1 Fwd fused sub-panels, 1@ DeltaVolt Pro 60A PS4 (4-bank) backup charging with AC generator.
- 234 Forum & Website
