Combox connection
stmar
Solar Expert Posts: 373 ✭✭✭
I have a Combox hooked to a wireless router which talks/connects to my main network wireless router. It has worked for the last few months no problems. Had a power bump this morning, router is on a grid circuit along with the main router. Now I cannot get the Combox/wireless router to connect with my laptop. Network is fine, can connect to the internet with no issues. I did a reset to the wireless router and to the main router. Any ideas on how to identify and rectify the problem?
I do much the same thing. In the glitch, your router may have assigned a new IP address to the combox, and you need to run the combox finder to get it's address again http://192.168.0.107/ is where mine sits
A trick from Schneider (from my last phone call to them) is to power down the combox, AND it's ethernet cable for 5 min, then reboot the combox and then connect the ethernet. Sneak power from ethernet can keep the combox half alivePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks, I'll try that.
Did a complete reset/installation protocol: thumb drive, power cycle, modbus disconnect per Quick Start Guide and it worked. I did not even lose settings that I had previously changed: time/date, password, etc. It also had the same ip address so I don't know what the problem was. The power bump may have scrambled something to keep it from communicating. Thanks for the 5 minute suggestion, I probably would have been a bit quicker.
- 621 Discussion Forums/Café
