Whats the most efficient solar setup I can have within 50 amps?
- Whatever array I set up is limited to 50A at 13-16VDC running between the charge controller and the inverter.
- I'd prefer a setup that includes parallel wiring over series, because camping tends to include unpredictable shade, and I'd like to maximize my potential.
Welcome.
If you have a MPPT controller, and connect it's output to another device input ( your Samlex ) and the Samlex attempts to regulate the battery charge, that will drive any MPPT controller nuts. Likely to drive a PWM controller nuts too. But you are welcome to try it anyway and report back how it works.
50A @ 16V = 800w of solar harvest (about 1,000 w of panels). If you are planning on 37A, you need a controller rated at 40A output..
MPPT controllers are rated at output amps
PWM controllers are rated at input amps
You could use a Morningstar MPPT -60, and program it to limit charge amps to 40A. The -60 has a nice internal web server, they are silent and rugged. And need air for cooling.
i use a DC input breaker on the solar side of all my MPPT controllers, if you need to reboot the controller, the solar goes OFF first, and ON after the reboot finishesPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
mike95490, Thanks for your reply. I'll e-mail Samlex tech support to see what they say about how solar chargers behave on the external port. Perhaps they have recommended settings for getting it to play well, which might point me to a MPPT controller that can also be programmed specifically.Amp ratings of the two types of controller makes sense. I probably should have known that one logically, and I'll probably just make a small breaker to disconnect both poles on the PV side. I did most of my initial research through blogs and websites that talk about adding solar to an RV/van electrical system, and nearly all of those guys only break the positive side of the PV circuit, same as you would a battery switch, but all the resources I check out that detail larger systems always break both poles to disconnect solar. I'm going to assume then that its safer to break both.So after a bit of what I hope isn't broken math, I've decided to size something between 400-600 watts. That amount of panels will fit well on my roof, and my battery is only 180Ah (LiFePO4), and I'm estimating that we'll need 120Ah a day at the high end. Heres my extremely rough estimates for my options:Based on a 100W panel operating at 6A in full sun (at 16V), and producing 20-25Ah a day, and x 1.25 for a safety factor in sizing the controller:
400W (4 x 6 x 1.25 = 30A) - 35A MPPT
500W (5 x 6 x 1.25 = 37.5A) - 40A MPPT
600W (6 x 6 x 1.25 = 45A) - 50A MPPT
Is this a reasonable estimate for sizing the array for my battery? If my math isn't too far out of line, 400W could produce between 80-100Ah a day, which is slightly below my needs but cheaper to set up, and 600W could produce between 120-150Ah a day, which meets my needs, so it will probably be the path I take.
I've been looking at the Victron series of MPPT controllers. They seem to be priced right in the middle between the more industrial brands and the cheaper brands and I've read good things. I also already use their battery monitor, so it would be handy to be able to monitor both through the same app on my phone.
Unless I'm trying to save money, is there any reason 600W of panels and a 50A MPPT controller wouldn't work for me?
On my 3 large systems, only the + side has breakers, The minus is grounded. If you don't use a grounded system then you need dual pole breakers
Does Victron allow you to configure your own voltage setpoints and absorb times ?
You don't want to configure a system that only meets your needs on good days, because even a slightly bad day is a lot worse harvest.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Makes sense on the grounding, I'll have a ground bar in the trailer so that might be an easy solution.And yes, Victron's "smart" controllers allow changing of all settings and creation of user defined charging "presets". I wouldn't mind recommendations for a 50A MPPT controller, but from what I've researched, any controller under $300 seems to have poor reliability ratings or exaggerated specs, and anything from well known companies priced above Victron's 100/50 ($320) is priced a good bit higher.Would there be a significant change in performance between 24v panels on MPPT vs 12v panels on PWM?
Seems like 600W is where I should be, and though I know 2x 300W, 24V panels and an MPPT controller could be considered ideal, I could also go with 4x 160W, 12V panels and a PWM controller which would be cheaper if the performance difference wasn't significant.As far as I know, PWM controllers aren't programmable, but I heard back from tech at Samlex yesterday and was told that I shouldn't worry about how solar chargers react on the EVO units solar port. They always pass through current and the programming priority is handled by the internal computer of the inverter/charger. Programming an MPPT in this instance would simply mean being able to tell it to keep pushing current until the EVO unit shuts off charging when the correct parameters are met.So for me and my small mobile system, does PWM make more sense? I'm not sure of a good resource to calculate the efficiency differences coming from panels of the same wattage. -
Morningstar and Trace PWM controllers are adjustable.
Trace has knobs inside, Morningstar requires a computer cable and their free MSview software
https://www.solar-electric.com/c40.html or https://www.solar-electric.com/tracc6060amp.html
https://www.solar-electric.com/tr60amp12244.html
and the 30A brat, cheap enough to use 2 systems, but I don't know about adjustments
https://www.solar-electric.com/midnite-solar-brat-pwm-solar-charge-controller.html
On a 600w system going to a 12v battery, would I see a significant difference between 24v panels and an MPPT or 12v panels and a PWM controller?Its the only decision I'm stuck on now, price for the panels seems to be comparable depending on where they're purchased from, so the difference seems to be about $150-200 between a 50-60A PWM vs 50-60A MPPT.If the efficiency difference is noticeable that price is justifiable to me, otherwise a PWM makes more sense.
Normally you would see about a 10% difference. A lot of the newer 12 volt nominal panels have a VMP of 18.9 volts so you might see an addition 5% (15% total).robts said:On a 600w system going to a 12v battery, would I see a significant difference between 24v panels and an MPPT or 12v panels and a PWM controller?
I think since your position to the sun will be compromised you might prefer a MPPT type for a bit higher performance from your limited area, that's a $$$ vs performance choice so all yours!robts said:If the efficiency difference is noticeable that price is justifiable to me, otherwise a PWM makes more sense.
Photowhit, sound advice. I forgot to factor in that the top of a trailer is much less predictable than stationary panels, might as well maximize my opportunity if the difference comes down to $150.Between you and mike I think I'm all set.Thanks for all your help!
