Remote readings of battery voltage?
softdown
softdown Solar Expert Posts: 4,062 ✭✭✭✭
Winters here can be quite severe here. With terrible weather sometimes I pretty well stay in the warm bedroom. Would be nice to see battery voltage though.
Outback inverter and charge controller. 48V battery banks. Guess I could run some ~20 gauge wires from the bank to the bedroom and a voltage meter. Though three active dogs have their way with too much stuff that isn't bolted down. Thinking it possible that Outback may offer a remote read out by now?
The Outback equipment is a bit of a chore to get to during the winter due to insulation over the stairs and....
    Hmmm... Did a quick search on Amazon and found one meter (no reviews) that was wireless for $45 with 10 meter range.
    https://www.amazon.com/DYKB-Voltmeter-Multimeter-temperature-Remaining/dp/B07GD6Y6KX
    And there are a lot RS485 remote meters (with lots of Volts/Amps/Hours) LCD displays for less than $50. I am surprised how much is out there... I just searched for "wireless voltmeter".
  • softdown
    Thanks, that is the 500 amp unit. Once can save a few bucks by going with, say, 200 or 300 amps. Wondering 'bout that.
    The list price for shunts is not cheap:
    https://www.solar-electric.com/search/?q=shunt
  • softdown
  • Horsefly
    softdown said:
    That's not a shunt though. It's just a bus bar. In this case, it is intended to increase the number of things you can connect to the shunt. Me thinks the host should change the name of the item to reduce confusion.
  • softdown
    Horsefly said:
    Being an econ major it looks like profit to these eyes. Compromise - Profitable bus bar for shunt
    Note that the NAWS website may offer you lower pricing (than website "list price") when you create an account and login.
    But they are "bus bars" for a "shunt"...
  • benthere
    benthere Solar Expert Posts: 113 ✭✭✭
    Why not use a Mate?
