Panels test different than summer time
KhellSk
Registered Users Posts: 91 ✭✭
Hello everyone,
I have these panels that last summer with full sun on, tested 20v and 3.3 amps
Did the same thing couple days ago (winter) with clear sky facing sun as well
Tested 20v 1.25amps
@Photowhit ( panels alone, no load ,no battery, no charger)
Whats going on ?
Tested 20v 1.25amps
Whats going on ?
_____________________________________________
[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah]
[Victron 50/100 700wMax MPPT]
Are you testing them 'short circuit' not connected to anything? Or are these measurements off a charge controller?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Winter sun is much weaker than summer in most places that get snow.Off-grid.
It is amazing, but by our eyes, a 50% reduction in light is barely perceptible.
Low winter sun angle, any haze/smoke/clouds, and you will get reduced current (Isc is more or less proportional to the amount of sun on the panel).
If all of your identical panels are reading the same Isc current (short circuit current), then all is fine. If you have one panel that is reading 50% or less of the Isc of others measured in the same place, same angle, and same time--Then that panel (or its connections) are questionable.
All are approx the same. Its impressive that it isnt perceptible like you said. I really wonder what people do during winter... my charge controller cannot take more than 400w. To compensate for the lack of luminosity i would need to double my array but a charge controller is limited.BB. said:If all of your identical panels are reading the same Isc current (short circuit current), then all is fine. If you have one panel that is reading 50% or less of the Isc of others measured in the same place, same angle, and same time--Then that panel (or its connections) are questionable.
How would one find a good balance between C rate and amd wattage winter compensation_____________________________________________[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah][Victron 50/100 700wMax MPPT] -
PWM controllers do not have the ability to regulate the "extra current" from a solar array. You are stuck following their array configuration requirements.
MPPT type controllers are more flexible--And you can over panel to a degree just fine. There are secondary issues (any electronic device running at max current gets warmer than one running at 80% of rated current--Extra heat is always a difficulty... Can cause shorter life for electronics, especially if there is poor cooling / warm closet space). Oversize array in hot summer climate in a hot garage/battery shed--Your choice...
Thank you_____________________________________________[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah][Victron 50/100 700wMax MPPT]
Have you adjusted your panel tilt for the changing orientation of the sun? In my area, accurate orientation varies from ~ 22 degrees in June to ~52 degrees in December.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
