Hump Day
mcgivor
Solar Expert Posts: 3,854 ✭✭✭✭✭✭
To all northern hemisphere members Happy Hump Day, the days will begin to get longer. To all southern hemisphere members, six months of decline, your Hump Day is in June.
We actually had a pretty sunny day here in Northern Calif, and that made my batteries that had been living on generator for last 5 days, very happy. I harvested about 15kwh, used 6kwh doing laundry and other stuff and charged batteries with the rest, and got about 15 min of float !Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 230 Forum & Website
