options to extend grundfos CU-200 SQ Flex control float switch distance
kilewillis
Registered Users Posts: 4 ✭
Hello fellow offgriders,
I am moving my gravity fed 3000 gal water tank to a higher location on the property and now will be further away from the grundfos CU-200 SQ Flex control box, past the recommended max distance of 1650 feet with 18 gauge wire. I was wondering if anyone had any suggestions on extending the range of the grundfos CU-200 SQ Flex control float switch. Perhaps some sort of a linear booster? or has anyone ran larger control wire to possible extend range? Pump and cu-200 controller is powered solar direct, no battery or ac nearby. I do not want to use a pressure switch..... I would like to keep the system simple but am not opposed to doing a wireless controller but only if I have to.
thanks
You can go to a larger gauge wire, 16ga or even 14ga for longer distance. I ran 18ga for my float switch and it controls a relay for the pump, not sending any real power over the long (1,000 foot run to my tanks)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 232 Forum & Website
