buffer battery size
NMNeil
NMNeil Registered Users Posts: 5 ✭✭
My very first post.
To begin, I am well aware that my 'project' is totally uneconomic, as is my existing small solar set up, but that's not my concern as I'm a devout tinkerer.
My plan is to run my 120 volt inverter mini split A/C from solar, but not in the normal way so I need help calculating the battery bank capacity and possibly other parts of the system.
I live in SE New Mexico and my roof orientation is due south so I can harvest the maximum amount of energy, but I only want to power it when the sun is shining. The house is on a massive 3' thick concrete pad so this will be used as thermal storage to store the 'cold' during the day to keep the house cooler at night.
The absolute maximum the A/C will draw is 1200 watts, but normal running will be around 800 watts, and according to the manufacturer it's soft start so no surge current and it will work happily with a modified square wave inverter.
I understand that I can't run the inverter directly from the panels as we do get the occasional cloud which may shade the panels for a few minutes, so I will need a battery bank as a buffer. The only thing is that I can't work out how much capacity it will need to keep the A/C running for about 15 minutes when the panels output has dropped to about 10% of maximum. (Just a guess number)
My thoughts are for 2Kw of panels, MPPT charge controller and a 3Kw modified sine wave inverter. I would prefer to stay with FLA batteries.
Can anyone help?
  • Estragon
    1200w load for 15minutes is 300 watt-hours.  A MSW inverter may run the load, but likely not particularly efficiently, so add (eg) another 100wh.  If we keep cycling to say >60% state of charge (40%discharge), we need 400÷.4=~1000wh storage, so something in the 100ah@12v range.  40% discharge rate is quite high, so an AGM type battery capable of that fast a discharge rate would be better in this application.
    The charge controller would need output to control the AC, so it's turned off if battery SOC drops too far before the cloud passes.  This does potentially cycle the battery many times/day.
    Another strategy might be to turn the AC off if pv power < AC load for say 1 min (to allow for orderly cycle completion), and optionally turn on if/when a high-ish temp is hit, and off again when battery hits (eg) 60% SOC.  This effectively uses thermal mass storage to cover short cloud events rather than frequent battery storage deep cycling.
    edited November 2018 #3
    Get a high end charge controller with programmable relay output, to control a well pump Contactor or inverter enable control line
    Set the cut-off voltage to Float -0.1V
    Set cut-in to Float +1.0V     (may have to adjust these a bit for your individual situation)
    won't run batteries down overnight, and you should be able to get by with a small battery.
  • mcgivor
    Due to the unpredictability of weather, it would probably be impossible to calculate with 100% accuracy a battery bank capacity that would work. The cycling of the batteries has the potential to leave them in a partial state of charge at times which needs to be replenished, lead acid batteries require long periods of absorption to complete the charging cycle, it would be a hit and miss situation at best, unless some  controls are added to prioritize the available PV to favor the charging needs first. The need to prevent the cooling unit from running without available sun intensity is obviously important to prevent the batteries being unnecessary discharged,  something like this
    https://www.merkasol.com/SUN-SWITCH-Light-Sensor could be used.to disable/enable the unit allowing the batteries to receive what is available should they need.
  • NMNeil
    Thank you all. A great deal of information to digest
  • bill von novak
    bill von novak Solar Expert Posts: 892 ✭✭✭✭
    NMNeil said:
    Can anyone help?
    To add what other people have said, I'd also recommend a battery charger that kicks on and charges your battery to 100%, say at midnight.  If you are using lead acid, having the battery regulary be at close to 100% charge is important for battery life.
    I would also add that there are now mini splits that will work directly off solar.
    https://www.minisplitwarehouse.com/product/ymgi-12000-btu-220v-solar-assisted-mini-split-heat-pump-air-conditioner-wmms-12ks-v2b56pv-mc295
