400 sq ft weekender cabin, off grid, designed for cooling
2»
  • Estragon
    I'd run the generator at 120v to both, unless you have 240v loads.
    The generator wouldn't be loaded that much, so not a big deal, but running 240 limits capacity to 1/2 per leg, and could be an issue if one leg was loaded much more than the other.
    I have mine wired for 120v even though I now have a 240v pump.  I figured it was better to use an autoformer for the pump rather than deal with the leg load issues.
  • Mike 870
    Mike 870 Registered Users Posts: 42 ✭✭✭
    Here is my final video with shoutout to NAWS at the end.  My system isn't really done but I want to move on to other topics as far as the videos are concerned.
    https://youtu.be/vNQ9d-13QO8
  • MrM1
    MrM1 Registered Users Posts: 487 ✭✭✭✭
    Very Cool.  Great Video and set up.
  • Mike 870
    Thanks Mr. M1
  • Mike 870
    I expanded my system with stuff mostly purchased from NAWS.  I added a East and West facing array each on a new charge controller.  Still a slow work in progress but getting there.  Cabin is coming along slowly and steadily.
    https://youtu.be/MuNLANBqZLg
  • softdown
    softdown Solar Expert Posts: 3,963 ✭✭✭✭
    You sound pretty darned experienced while talking.
  • Mike 870
    Ha ha, well I try my best.  I've done a couple RV installs in addition to this.   Most of what I know I learned from reading stuff here...
    If you can get at them, taking a few of those shade creating branches that is, you will get a lot more  output for your batteries. The shade of even a small Aspen branch can cut production by 50% or more...  have fun.
  • cjpetrie
    cjpetrie Registered Users Posts: 4
    This is one reason I built a ramada for solar and rain water collection first and put the house in later. https://www.lulu.com/en/us/shop/charles-petrie/ten-years-off-grid/paperback/product-1dgpvmym.html
  • Bluedog225
    Bluedog225 Registered Users Posts: 27 ✭✭
    What a great project!  Thanks for sharing this.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,138 ✭✭✭✭✭
    All I'm getting is a link to buy the book. Am I missing something here?
  • NANOcontrol
    NANOcontrol Registered Users Posts: 280 ✭✭✭
    Have you considered concrete siding like Hardie.  Square footage is pretty cheap.  I built a 24X24 garage and only had a little box of scrap left from the entire job.  Try doing that with vynal. Paint will last on it forever and not peel.  After 12 years my paint still looks new and this stuff won't rot.  I live in a high moisture area and this was the clear choice not to mention fire resistance.  I had a big saw and found that an angle grinder with thin metal cutting disk was easiest to use.  A proper nail gun is a must. Who doesn't want another tool.
