Snow is coming
wellbuilt
wellbuilt Solar Expert Posts: 763 ✭✭✭✭
Hi all , the snow is coming , how do I manage my system over winter .
 I plan to leave the inverter off but the rest of the system uses power if the panels get snow covered the battery could be depleated .
 I plan on working up at the house every other week end ,but could get snowed out .
 Could I leave my LA battery’s @ full charge and just turn off the system ?
 I could charge with my genarator when I’m there .
  How long can they sit with out damage .
  • mcgivor
    Hibernation is what the animals do, batteries become less active in the cold, turn everything off and let them hibernate, less to worry about, there are charts for various chemistries and their self discharge with relation to temperature, most/all are inactive in the cold.
  • wellbuilt
    Thanks mcgivor , how long could the battery’s sit with out charge .
     I’m sure it will be @ freezing in the battery box .
     I have  16 golf cart battery’s
     I’m sure I’ll be ok for a few more weeks but the time is coming
  • mcgivor
    Just make sure they are fully charged before storage and refresh charge when possible or after hibernation, you didn't mention FLA or AGM, perhaps a good time to create a signature so we don't have to guess or assume  :)
  • Estragon
    Estragon Registered Users Posts: 4,498 ✭✭✭✭✭
    A fully charged L.A.  battery is okay to ~ -75°f.  With zero load in freezing temps, they'll self-discharge very little, and should last until spring.  My boat bank does fine, and temps can get into the -40s.  Some years I give them a top up mid-winter, but they're still okay even if I don't.
    At the cabin, I leave the charge controllers on though.  Although small, they are still a load, and will drain batteries to a point where they could freeze in a matter of weeks if panels get covered.  I ended up adding some panels mounted vertically to ensure there will be enough to offset CC load if the big arrays get covered.  The alternative would be to turn them off.
    edited November 2018 #6
    More or less, the starting estimate is the engineering rule of 10C 1/2 or 2x change in life... And self discharge.
    Say a FLA battery needs to be recharged every 1 month due to self discharge (going from ~100% to 75% State of Charge is "normal storage" range) at 25C (77F). And your batteries are at -5C (23F) or lower during the off season... That is 30C / 10C = 3x groups of "2" (or 1/2).
    1/2 * 1/2 * 1/2 = 1/8 slower discharge (longer life)... 1 month * 8 factor for cold temperature = ~8 months between recharging and self discharge (when at -5C or lower storage temperature). As long as the batteries start at ~100% SoC when you put them down for winter.
    If you choose to run a solar panel/array during winter with a solar charge controller--You can do that too. Mounting panels high and near vertical (if you have drifting snow), or a couple panels on the side of the building with a smaller charge controller (PWM if "12 volt panels", MPPT if needed)--Using a larger charge controller (the Midnite Classic, Outbacks, etc. that are >60 amp MPPT controllers, Ethernet remote comm, etc.)--You run the risk of snow blocked panels and the controllers discharging the battery bank over the multiple months of controller load without sun killing your battery bank. Smaller MPPT controllers (no ethernet connections, simple PWM controllers) have lower self discharge.
    For example, Midnite is nice enough to give us the standby consumption of 2.5 Watts per MPPT charge controller (Outback FM 80 is <1 Watt):
    https://www.solar-electric.com/lib/wind-sun/Classic-specifications.pdf
    https://www.solar-electric.com/outback-power-flexmax-fm80-150-mppt-charge-controller.html
    • 2.5 Watts * 24 hours per day * 12 weeks of winter = 720 WH per "winter"
    • 720 WH / 12 volts = 60 AH of discharge current @ 12 volts
    And any other loads you may have (cell phone alarm system, battery monitoring system, etc.). And make sure that no inverters (or other unneeded loads) are accidentally powered up (or even on standby)... On standby a "full size inverter" may draw 6 Watts on standby and 10-20-40+ Watts on with no loads.
    Also, you want to make sure that the controller stays in float charge (low voltage charging)...You don't want the controller to go into absorb state charging very much during the off season--Nobody there to watch the water usage.
    And watch "new installations"... You don't want to set up your new "winter float" system the day before you leave--You want to have it working and monitor it for at least a few days to make sure it is doing what you want.
    From what I have read here... It is 75F for a high today, and we get "snow" every 20+ years that goes away in a few hours. Not the cold weather expert.
  • wellbuilt
    I will leave the inverter off and solar charger on for now and watch what’s happening .
     I should be up there every 2 weeks .
     If the out back fm 80 uses 1 watt 24 watts a day that’s not to bad .
     I’m hope the panels will be clear of snow , time will tell .
     At the point the panels get snow covered I will charge up to full and leave the system off .
      I could snow shoe in to check things out .
     Or maybe keep the place plowed  I get a lot of snow up there  thanks for the Quick response
  • wellbuilt
    Has any one use one of these ? I was trying to get my battery’s ready for winter . My system was put in service 10 weeks ago .
     My 2 strings of battery’s where very close to full charge and I figured the 2 strings of 8 gc230 ah battery’s would grow closer once they where being charged together.  (Wrong)  both strings where kind of all over the place .
     10 battery’s where about 1.275 the rest where 1.265 1.55 one was 1.230 seam like a big spread for 10 weeks of weekends and low usage  the system sits on float for 4 days a week ? It was 50o in the battery box I did not bother adjusting the numbers ?
     The easy red gives me good reading  just above 1.275  on all the battery’s , the other hydromader is all over the place
     some where 1275 as a high to a low of 1230+-  the easy red reads water a little higher and I figure that is why I’m over on the full charge reading 1280/1285  how do I tell if the  hydrometers are  accurate .
     My absorb is 59.2  for 3 hours. I pushed it to 31/2 hrs float 54  for between 11/2/31/2 hrs  A day
      I did not have time to EQ and the sun was going down     What do I need to do ?      Thanks in advance john
  • Estragon
    I had lots of trouble reading my glass float type meter.  Even with repeated rinsing, it often stuck instead of rising to an accurate read level, so it often took 4 or more reads/cell to get a decent sense of things.
    I switched to:
    https://www.solar-electric.com/midnite-solar-battery-hydrometer.html
    It still needs rinsing, and sticks occasionally, but way less than the glass one.
  • wellbuilt
    Thanks estragon , just bought one from amozan
    Since they are new batteries, it will help you if you record the SG values for each cell, then you have a base line of the starting  SG's and also record the voltage of each battery...  with all those batteries you will have a head full of ' now what was that SG??' running through your head.
    I use the 2 PV's vertical on an outside wall as a safety net now  just in case, we were pushed to get out before we got snowed in, a few years back, and when we got back 2 months later, the CC was still on but the batteries lost a few years of life at a minimum!
  • wellbuilt
    My system was put into service 9/10 weeks a go and all the battery’s where close 1275 1270 I thought they would grow together once combined in the system .
     I seam to have a hard tome reading SG the easy red reads good ( maybe all the time ) the other on is all over .
     It seams like it’s sticking but I did rinse it with distilled water every time I used it .
     I bought a new hydromador mid night solar battery hydromitor  and see how it works.
       I will start keeping a log starting this weekend .
     My solar panel are getting covered in snow now ,  hopefully it melts off .
       I dont  really have a good spot for Vertical panels to sit in the sun now , im treed in till next year .
        I plan on working there thru the winter if I can get in . So I was thinking I would just turn the system off when I leave
       I could snow shoe in if I have to and top up the battery’s .
  • Estragon
  • wellbuilt
    Wow that is a great spot.
     That’s  the type of property I wanted,  but any thing with water is just so far out of my reach  financially .
      Taxes here on a piece of land like that would be 30k a year .
      We have a place in lake George ny , 2 blocks from a 500’ beach area taxes are4500 a year slide that house to the water and the taxes jump 4.5 times about 22 k plus  , all the old timers had to sell out and head to the reast home , I didn’t want to be one of them I’m in the Mountains
  • Estragon
    Taxes are ~$1500CAD/yr (for zero services, mind you).  The snowshoe hike is ~3mi, mostly across ice, with a short portage.  Not sure I could hack it in the mountains.
    Nearest neighbours are near the cleared bit past the points to the left of the snowshoe trail, a bit over a mile away.  Very quiet, especially in winter :smile:
  • wellbuilt
    edited November 2018 #16
    Very nice , who need services anyway , in ny the towns don’t do much to help you , no water or sewer no trash pickup  there are police but they are not really a help in my eyes any way.
     If I was sick I can’t call out most of the time  I can text and it will go thru  eventually but I can’t text a 911.
    Im at the top of a 2 1/2 mile long Mountain Road  with six houses and two full-time residences.
     We had a 16 ‘ snow drift across the road  that the town pushed off with a cat loader , I get the same drift across my driveway .
     I’m hoping I can handle the  mountains as age .
  • mcgivor
    Property taxes drove me out of Canada, Vancouver in particular, the changing demographics fueled by offshore buyers were responsible for the upward trend of property values, this however resulted in increased property taxes. Starting in 2000 when I purchased taxes were $710 per annum on  a property valued at $165 000, by 2015 the taxes were $3700 value $890 000, so sold and decided to move as my income was not proportional to the rate of increase.  Now with 15 Acres in Thailand my annual tax is $6, no services, none expected, Ironically the value here has also increased ten fold in ten years but the taxes  remain constant. Go figure.
  • wellbuilt
    6 bucks is really good😋 I’m going to try to stick it out  here in NY , my wife is ageing in dog years .
     She is liking assisted living but that’s not for me .
     I’m pushing 60 now  I’ve gotten old the last few years .
      There is a lot of work to do  living in the mountains in the middle of nowhere  I hope in up for it 😎
    edited November 2018 #19
    Just make sure you get 90% oft the heavy stuff done before you have open heart work done, it takes about 2 years before you 'feel' almost normal,  like you did before the operation... :):) :
  • softdown
    softdown Solar Expert Posts: 3,963 ✭✭✭✭
    Epic thread drift. Pretty good at it myself but feeling completely outclassed at the moment.
  • wellbuilt
    edited November 2018 #21
     My heart is in pretty good shape working outside my whole life ,   Cancer  got my mom last January so I’m thinking I will go that way .
     Can’t afford the copay on a heart job any way .
     I’m working double time up here trying to get done , but it will be a couple more years .
     No power for me today . I hope the stuff melts off  but we haven’t had any sun since it snowed Thursday .
     I’ll have to ground mount another 15 panels on the ground so I can clean them off .
  • Porschephanatic
    Porschephanatic Registered Users Posts: 62 ✭✭
    I saw the photo, and thought at first that it was my brother-in-law's. Snow on his panels, too.    : (
  • wellbuilt
    Ya , it’s been dark all week really .
     Driving home today at 330 every one had there lights on .
     Just my luck. I have my system up and running and some one put the sun out 😖
  • wellbuilt
    Ok here is my new Plan . I can’t believe how this little genarator is working with my system .
     I must of run this little guy 6 hrs on1/2 a gallon of fuel .
     The only problem is the price .
    Which model? cant quite make it out..
    that consumption rate is almost as good as the (my) 1000i model !
    EG2800i it appears...
    Bill
  • wellbuilt
    Yes eg2800i  I think it has a 12 hour at 1/4 load run time , but it seams like I was doing way better then that .
     I started charging at 21/2200 watts   The charger was set to 20 amps I was thinking it should be up around 2400
    20ax120= 2400 ?
     But the charger started at 90% and went up to full charge in less then a hour .
     Charging dropped to 500watts the Honda just ran smooth and quiet .
    Hmm... The spec sheet says:
    http://m.powerequipment.honda.com/generators/models/eg2800i
    The EG2800i operates up to 12 hours using only 2.1 gal of fuel.
    Fuel Tank Capacity2.1 gal.
    Run Time per Tankful5.1 hrs @ rated load, 12.1 hrs @ 1/4 load
    AC Output120v 2800w max (23.3A) / 2500w rated (20.8A)
    Was this Watts or VA measured... A lot of (transformer based) battery chargers have very poor Power Factor (Watts=V*A*PF) at low charging currents.
    Good catch Bill, I looked and saw he has a OB 3648 Inverter charger and assumed the FULL  Charge was  based on that OB reading
    Up here that unit sells at the same price as my 2000i lunch-bucket .... you have to wait for the Xmas sales for a deal....
  • wellbuilt
    No bill I didn’t check the va I’m just happy the thing works.
     I filled the unit with fuel and ran 3  Timed charging  cycels 2 hours each 2 bulk charge 1 EQ I had 15 mins warm up / break  in with no load .
     My first bulk absorb charge went from 90% up to 100% in 11/2 hours and I stoped charging at400 watts going in .
     I was charging at 2100 watts on my mate  display for 20 mins then started backing off slowly
     The Eq started at 1400 watts but went down to 4/5 watts in 15 minis and stayed ther for 2 hours then timed out .
     The next bulk absorb charge went from 87% to 100% in 1. 40 min
     I was drawing low watts for most of the time .
     I refilled the unit with a 1 gallon can and it looked to be half full +- maybe a pint one way or the other
     west branch all readings where on the mate screen I switched the genarator to eco after the charging started and at 2100 watts the hound did slow down a good amount .
     The house was pulling power all so light radio Mikita charger .
        I’m happy so far  John
