New Solar Invertor owner, error, help? :(
CDM
CDM Registered Users Posts: 2
Hi, I just had a 2 solar panel, 2500w invertor package installed by my rv dealer; and I can't run the thing more than a minute before it starts beeping!
I start it up; fridge is on gas, basically nothing is plugged in;
It starts are 11.8v, 0.0A, 41%right  now (strange because I had been driving/ had it plugged in right before I left earlier today.)
The numbers show that the voltage drains down to 9.7 over the course of a minute ,says "INV -146.5....and moved up to -150 over the course of a minute, before giving me 4 beeps repeatedly,  and the power button on the remote goes red, saying
UVP Shutdown
I'm on a work trip and need this thing performing. Help? <3
Model is a Go Power! GP- ICR - 50
  • petertearai
    petertearai Solar Expert Posts: 471 ✭✭✭✭
    battery voltage looks to be too low . Investigate why ,  maybe a charging problem . 12.6 Volts is approximatly a fully charged battery .
  • mcgivor
    edited November 2018 #3
    UVP Shutdown
    Welcome to the forum CDM
     More information is needed, no mention of battery, charge controller, panel wattage etcetera, most of us are not clairvoyant, so more details would be most helpful.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    That's a huge inverter. What are you powering that would need that much power?  You should have 4/0 cables connecting the battery and inverter.
    An inverter that size will drain a I-2 battery sized bank all by itself with no loads at all in short order if it has been left on .
  • Estragon
    Does the RV have a shore power system, and if so, is it plugged in?
    This appears to be a MSW inverter designed for portable use.  If tied into an AC system in which neutral and ground are bonded, either in the RV or in shore supply, bad things can happen.  If this is remotely possible **DON'T USE THE INVERTER until this is checked out**.
    This unit doesn't appear to have an internal transfer switch, so it would have to be wired properly into an external shore power transfer switch.  If not, this type of inverter may create a dead short internally, which would account for the sudden drop in battery voltage (and will destroy the inverter, and potentially the RV).  Could be something else, but best to rule this out!
  • CDM
    I'll guess I'll need to get some more information together before I can get a more solid answer on this; thanks everyone!
