Using a 18v solar panel on a 12v system
bigslo
bigslo Registered Users Posts: 1
Hello everyone,
I recently bought a hybrid inverter, Luminous NXG 750 which according to their technical specifications (attached image, highlighted in red), supports solar panel of 12v upto 400wp.
A friend of mine gave me four 18v solar panels (atached image) that i wanted to use on the inverter. When sitting in bright sun, i measured around 21-22v, and in shaded areas, i measured around 15-16v per panel.
Is there any easy way to reduce the voltage to a safe level for use in my 12v rated inverter without having to open the front glass pane and rewiring the individual solar cells. Any help would be greatly appreciated.
    Voc~21 volts and Vmp~18 vols is the nominal voltage (standard test conditions/marketing speck) for "12 volt panels" charging a 12 volt battery bank with a PWM solar charge controller (sounds like what you have).
    Using a 400 Watt array (Imp~20-22 amps), you want to charge the battery bank at ~ 5% to 13% rate of charge... 5% is good for weekend/summer/sunny weather cabin. 10%+ is better for full time off grid system (9 months a year or more occupation)...
    • 400 watts * 0.77 solar panel+controller derating * 1/14.5 volts charging * 1/0.05 rate of charge = 425 AH @ 12 volt battery bank maximum size for weekend/summer usage
    • 400 watts * 0.77 solar panel+controller derating * 1/14.5 volts charging * 1/0.10 rate of charge = 212 AH @ 12 volt battery bank "nominal"/full time off grid
    • 400 watts * 0.77 solar panel+controller derating * 1/14.5 volts charging * 1/0.13 rate of charge =163 AH @ 12 volt battery bank "typical minimum" suggested battery capacity
    A pair of 6 volt @ ~200 AH "Golf Cart" batteries in series (for 12 volts @ 200 AH) would be a nice bank for this system... If mostly summer use (and/or you use a backup genset for bad/winter weather), 2x strings of these batteries (4x total) in series parallel would give you 12 volts @ ~400 AH.
    If you want to "reliably" use the 500 Watt output of this Inverter on your battery bank, I would suggest (~250 watts per 100 AH @ 12 volts) a minimum battery bank capacity of:
    • 500 Watt inverter * 1/250 Watts per 100 AH (at 12 volts) for flooded cell lead acid batteries = 200 AH @ 12 volt minimum FLA battery bank for this inverter.
    Assuming you are in/around Mumbai India, fixed array, 400 Watts:
    Mumbai
    Measured in kWh/m2/day onto a solar panel set at a 71° angle from vertical:
    JanFebMarAprMayJun
    6.54
    7.17
    7.42
    7.14
    6.69
    5.63
    JulAugSepOctNovDec
    4.94
    4.85
    5.69
    6.29
    6.46
    5.98
    You have lots of sun, relatively speaking... The long term average for your "worst month" is ~4.85 hours of sun per day:
    • 400 Watt array * 0.52 off grid system eff * 4.85 hours of sun average (August) = 1,009 Wh per average August day (some days/weeks more, some less depending on the weather patterns at that time).
    Lots of guesses and assumptions... Please ask your questions and correct my guesses.
  • bill von novak
    bigslo said:
    Hello everyone,
    "12V panel" means 18 volts.  If it is designed to work with 12V panels it will work with your panel.
    Note that this inverter requires a battery.
  • oil pan 4
    That inverter needs batteries, a charge controller in addition to the solar panels.
