2001 update
parbob1
Registered Users Posts: 40 ✭✭
Long story short build a house in the middle of the woods 2001 in the Northeast ...purchased SW 4024 inverter disconnect and battery pack charged by generator
. Sold the house and ended up getting it back in 2017. With every intention of installing solar panels. Inverter went bad so solar panels will be moved to a 2019 project
what I have now 8- 6vt 235 batteries and a 6500 Honda generator and disconnect/breaker.
What I’m shortly going to,purchase
Schneider SW4024 Inverter 120/240V
Schneider Conext System Control Panel
Schneider Conext Auto Start Control
12/24V Battery Vent Fan Control
am I missing anything, or making any mistakes
SW Conext 4048
AGS
Combox & Conext battery monitor
16- 235 6V batteries
Honda 6500 gen
Honda 6500 gen
Missing loads? Maybe 24v makes sense,, or maybe 48v? 120/240v inverter suggests maybe some bigger loads that might be better at 48v?Off-grid.
I'd suggest getting the ComBox instead of the SCP - if you are able to connect a router and computer to it. The SCP is lots of manual button pushing and scrolling. The combox lets you use a mouse and PC to do that, and see a bit more, install firmware updates (or brick it if you do it wrong)With 8 batteries, wire in series and use a 48v system, not 24VPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thank you I did not know Com box could replace scp. Is the com box windows or will apple work?..
and I was mistaken I have 12 6vt 235 batteries.
my old inverter was 24vt and supplied all power needs.
With the new inverter producing 240v I was going to add 1/2 hp water pump
SW Conext 4048AGS
Honda 6500 gen -
If the batteries are fairly new and in decent shape, I'd consider adding to get 2 strings at 48v. Keeps wire/connector sizes more reasonable, and less voltage sag on larger loads.Off-grid.
So if I go 48v, can use my 250amp dc breaker box and 4/0 cable (10’)?
Batteries are newer.SW Conext 4048AGS
Honda 6500 gen -
4/0 wire should be fine. You'd want to check the inverter spec/manual for max breaker size.Off-grid.
Thank you for your help. I think I’ll go with 48 v and the com box.SW Conext 4048AGS
Honda 6500 gen -
250amp is spec for all of the SWs in the install guide on the Schneider web site.
The combox is a web interface, works with a browser, on my android or my win laptop. Should work fine with a mac too
