Is this a start of a practical solution for charging LiFePO4 batteries in temps to -20*C
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
Looks like a battery with an integral thermostat & heater. Without the heater, the battery will be damaged.
Presumably with the heater integrated, failure might allow for a warrany claim, vs an external heater failure which wouldn't.
The specs say max of one battery in series though, so limited to 100ah@12v. Hopefully my L16s will hang in until less limited.Off-grid.
Interestingly it says it takes 10A for 1 hour from the charger which would equate to ~130 Wh for a 12V nominal battery, the question is how many cycles of heating are required, in off-grid the charging is limited to a few hours per day, I would assume the heating is thermostatically controled, heating as needed, if so it may self sacrifice overnight, or dose it preheat before charging. They do come at a premium cost wise, almost 4× the price of loose prysmatic cells, my particular case is at the other end of the spectrum, but given the challenge of dealing with cold, my thoughts would be along the lines of commercially available heating blankets and a control circuit perhaps using a diode to clip half the waveform to reduce current as needed. Just pondering the question of how to solve the issue and fractional divisions thereof. Nothing serious.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Since LI batteries have so little internal resistance, very little self-heating in our "solar" environment. If used for starting a car in Alaska, they can discharge (crank the engine) and then, since in the colder climes - engines are left running, it would have the time to be heated, and then charged. On solar, it will hopefully not bleed itself dead overnight, and when charge voltage is applied in the AM, start it's heating cycle, and when warm, start charging, so you may loose an hour of harvest as it warms. If thoughtfully insulated in the winter, it may not chill to the point where it needs heat daily. Or throw a hot water bottle into the insulated battery box when you go to bed at night.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If you live there full time it is not that hard. Part time is a major mistake to use LFP, unless cost is not an issue. I have client like that and I like her for many reasons"we go where power lines don't" Sierra Nevada mountain area
I have charged lithium batteries at 3C and they barely put off any heat.
You would have to charge a LiFePO4 battery the size of a forklift battery to get it to build any useable heat.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
