600V Charge Controllers Morningstar or Xantrex
mcnutt13579
Registered Users Posts: 112 ✭✭✭
We have a few jobs upcoming that might benefit from a 600 volt charge controller. 9 or so 72 cell panels in a single string maybe, interacts with other factors.
We don't even know anybody that has a 600 volt CC or has used one.
Leaning toward the Morningstar for the first job because it is self contained with display and buttons but want to be sure it isn't a piece of junk or anything.
Both Morningstar and Xantrax are good controllers. If you are planning on inverter gear, if you use all Xantrex, they will use the Xanbus as a common communications and the Combox (with a computer via ethernet) is a good control & monitor device.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Likely will be an Outback inverter. Not going to be Schneider for sure.
mcnutt13579 said:Likely will be an Outback inverter. Not going to be Schneider for sure.
mcnutt13579 said:. Leaning toward the Morningstar for the first job because it is self contained with display and buttons but want to be sure it isn't a piece of junk or anything.
mcnutt13579 said:Likely will be an Outback inverter. Not going to be Schneider for sure.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
This job will be perfect for a single FXR, and no 240 is needed.Yes it is true that Schneider went full stupid some years back, and neither us nor our competitors, nor DIYers seem to use them now. I know of a total of 2 systems and one had full power meltdown and the other had software issues that should never happen on a piece of equipment that is expected to run 24/7/365.But those were the previous generation and my current research has led me to believe we will probably be using them very soon again.Anyway back to the topic, has anybody used either 600V charge controller or are we just trusting that the company knows what they are doing?
I beta tested for Schneider the 600v mppt-80 in 2010. I have installed and sold close to 100 of them. Zero problems! It is about all I use.
I always use a complete system to enable the user to get data from the home wirelessly or anywhere in the world. I like Outback but the 600cc makes my job very easy. The screen below tells a user in one screen most everything they need.
Outback will have a 600v all in one inverter and CC out in the next few months.
- 231 Forum & Website
