Omega power inverter model OP-W3K
Tienie
Registered Users Posts: 1 ✭
Why is there two positive and two negative connection points for batteries on this unit. Does it mean that i can connect two batteries on the unit..
More than likely it's to allow a parrallel feed from the same battery, heavy gauge is more difficult to work with, parallel runs can equal the required gauge or square mm. requirements of a single larger conductors, without the large lugs and conductors.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
