Opinions / Reviews on the Victron MultiPlus 3000 Watt 24 Volt Inverter & 120 Amp Battery Charger
tr0y
Solar Expert Posts: 99 ✭✭✭
Seems like lots of these are showing up in the RV market. I am planning a 24V upgrade to my RV has anyone here gone this route ? Thanks
The thing to do with any product that Amazon sells is to just read the Amazon reviews: https://www.amazon.com/Victron-Energy-Multiplus-Inverter-Charger/dp/B0054PRVAS/ref=sr_1_fkmr0_1?ie=UTF8&qid=1536072581&sr=8-1-fkmr0&keywords=Victron+MultiPlus+3000+Watt+24+Volt+Inverter&th=1#customerReviewsNote that Victron is absolutely nowhere near a top of the line products company, the way that Outback, MidNite Solar, Magnum, Schneider, etc happen to be. They are nicer than most of their made-in-China competition, sure, but that really isn't saying a lot, to tell you the truth. As a matter of fact, Samlex makes a better product IMO, and their product is slightly cheaper: https://www.solar-electric.com/samlex-evo-2224-inverter-charger.html
DoD= depth of discharge= amount removed from that battery SoC= state of charge= amount remaining in that batterySo, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoCA/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use) -
I'm probably going to get to get the non RV samlex 2,000w pure sine wave inverter, with out batt charger.
Looked at the Amazon link for the reviews and saw the price. I paid less for my Schneider Conext SW 4024.REC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
Victron is a very good product but probably not easily serviced here in NA. I have quite a few clients using them in Australia."we go where power lines don't" Sierra Nevada mountain area
- 234 Forum & Website
