Fuses plus breakers
Chris11
Registered Users Posts: 130 ✭✭
I had automotive blade fuses already installed in each of my 3 strings when I added breakers so I left the fuses inline. Is this a good idea or a bad idea? Should I remove the fuse holders and fuses?
Thanks.
Thanks.
not the best fuses, so i would remove them2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
Agree, remove them they'renot designed to hold high current for long periods.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks...I kinda suspected that would be the suggestion.
- 230 Forum & Website
