Off-grid system for the Honduran island Guanaja
Franz_Guanaja
Franz_Guanaja Registered Users Posts: 1
Hi,
I am living on Guanaja, a Honduran Island, and I am planning to install an off-grid solar system (or hybrid system) for my hous and neighbour houses. The main components are:
- 18 solar panels: 300WP each
- 1 LiFePO4 Battery: 12-15kWh
- Battery inverter
- Solar inverter
The details are explained in the attachment. I would appreciate it very much if anybody could help me planning the off-grid system. Hoping to get many answers!
    First the diagram should be corrected, as the DC volts go from the PV's to the Charge Controller, then to the battery, then to the Inverter to produce 120V/240V AC which would go to the loads... If you will maintain the Generator in the setup, or will use the grid to boost the batteries after use,  you would normally use an all-in-one Inverter/Charger. More later, domestic duties call..
  • mcgivor
    What make are solar and battery inverters?
    Why chose the Li battery instead of affordable LFA
  • MrM1
    MrM1 Registered Users Posts: 487 ✭✭✭✭
    edited August 2018 #5
    Because maybe the OP read the ever-popular "are lithium batteries the way to go" thread.
  • Estragon
    Not sure of the rationale for 2 pv strings. 270v is too high for a typical 150v off-grid controller, and low for a 600v one. Why not 1 string at ~540v?
  • Estragon
    BTW "off-grid" means there is no grid. In this case, there appears to be a grid connection.
    It may help to know what conditions or restrictions are applicable for connection to the local grid.
  • mcgivor
    SMA  makes dual input MPPT inverters with up tp~500V inputs.
  • MrM1
    edited August 2018 #9
    It would seem 12-15kWh for 4 houses will be pretty small (somewhere around 3kWh of storage per house),  especially since you will have no control over how much power  each neighbor would use daily.   Seems like a lot of unknowns.
    • Any idea what the TOTAL power needs from all house will be in Watt Hours per day?
    • How often will the grid be down and for how long?  Having lived in Honduras in La Ceiba I know it went down regularly there but not for long periods of time unless there was a natural disaster.
    • How many days do you plan for the system to operate without grid and sun (in the event of bad weather)?
  • mcgivor
    The Bay islands, at least Utila rely on generator " grid " supply, often shutting down at midnight, I remember that well, waking up sweating when the fan quit :#
  • Estragon
    That makes sense, though if O.P. already has specific gear in mind, it would be helpful to know.
  • MrM1
    I really liked the times I got to visit there in Utila.  I stayed at the Jade Seahorse once.  Cool ... odd place.  Seems like you have lived all over @mcgivor
  • mcgivor
    Spent 8 years worth of winter months in Central America, Canada was my home base, but the winter was not for me, until I found employment with a future, the rest is history, but oh the memories, they were good times.
