Outback FlexMAX 80 issue...
Rossk
Registered Users Posts: 1 ✭
I am hooking up my solar... I have 4 325W panasonic HIT panels and an Outback FlexMAX80 Mppt solar charge controller charging 4 Apex AGM 250A/H batteries(1,000AH total) in a 24V configuration. The problem is... when I turn on the PV array, the MPPT shows the correct voltage coming in and within about 8-10 seconds, the input amperage goes from 4A to 1.5A (it is in the morning and no clouds are visible. Basically bringing the voltage of 1 panel. any Ideas or suggestions? I have ruled out the parallel collection coupling as I now have 2 panels wired in series with the same issue. The voltage does not drop just the amps. Any help would be appreciative!!!
Are the batteries discharged or fully charged?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I'm not sure how you get 1000ah@24v from 4x250ah batteries. What is the voltage of individual batteries, and how is the bank wired?Off-grid.
Not sure what your issue is.Rossk said:I am hooking up my solar... I have 4 325W panasonic HIT panels and an Outback FlexMAX80 Mppt solar charge controller charging 4 Apex AGM 250A/H batteries(1,000AH total) in a 24V configuration. The problem is... when I turn on the PV array, the MPPT shows the correct voltage coming in and within about 8-10 seconds, the input amperage goes from 4A to 1.5A (it is in the morning and no clouds are visible. Basically bringing the voltage of 1 panel. any Ideas or suggestions? I have ruled out the parallel collection coupling as I now have 2 panels wired in series with the same issue. The voltage does not drop just the amps. Any help would be appreciative!!!
First off you have a 250ah system, not a 1000 ah system (assuming your batteries are 6V.) Second, if your batteries are fully charged that is exactly what you will see. So I don't see any problems there.
"Basically bringing the voltage of 1 panel." - Your array voltage will remain pretty much the same no matter what. Only the current will change. -
what is the controller saying .. Bulk ? Absorbing ? float ?
Do you have a load you can put onto the system, inverter or such . With a load it should increase in amps out .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
- 621 Discussion Forums/Café
