Solar Charging a 48V go kart
If A & B are where the AC power comes in, do not place a jumper across them. (well, I would not) The green disk thing looks to be a surge suppressor (oddly with a diode silkscreen under it??), if you are putting a jumper across it, you could just leave it in, or remove it to give yourself more room.But that layout looks not quite right to me, for a voltage select jumper set.Gauge, 16ga wire would work, 17 is a non-standard size, 16 is the next largerPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Well, I figured, lets give this a try.
I removed the screws from both of the ends to open the charger up. The housing is an enclosed box.
I figured the circuit board would just slide right out.
Nope, there are components that are soldered to the circuit board & also glued to the inside of the box.
But, luckily the area that I needed to work with was near one end & pretty easily accessible.
So, first I clipped the Lima bean looking thing out (as per the instructions)
Then, I soldered in (2) 16g. jumper wires (also, as per the instructions)
OK, now If it's supposed to be, preset to a 49V top charge, like I specifically ordered, right from the factory
…& NOT 50.4V or 54.6V like most 48V lithium chargers are.
What should the voltage be coming out of the DC output plug?
...49V?
