LG INVERTER REFRIGERATORS
LG has had a 22 cuft at the Sears store up here in the mountains. They still do and that is my replacement when the Maytag man wants to come visit me."we go where power lines don't" Sierra Nevada mountain area
fyi re GE compressor technology in fridges, we have one of these in our fridge, rated at 319kWh/yrhttps://www.youtube.com/watch?v=2km_KjdPIEo
Do you know if a 300w psw inverter (eg Morningstar) start the GE fridge?Off-grid.
My fridge has a +- 40 amp surge.... I know my Cotek doesn't have any problems starting. never tested smaller Wattage ones
Ok thanks. Pretty sure the little inverter won't handle that.Off-grid.
The one I linked above, I can get a scratch'n'dent version for about $850. It's annual KW is listed as 464.
If I divide it out correctly, that's an average continuous consumption of about 50w. I can handle a load like that. I need an excuse to increase the battery bank size anyway.
MrM1 said:
I'm looking on a phone and I can't find it. Is that an inverter fridge? -
Update on LG refrig running on 600 watt Samlex inverter. Running fine, but this inverter needs a note. As has been noted elsewhere the outlet on it is a GFI type. It will trip on occasion, especially if a power strip is attached. If your running a refrig off it and are away it could ruin a whole lot of food. Replacing the outlet with a DECOR type standard outlet solves this problem. You have to internally bond the outlet just as the installed GFI is. If your Samlex seems to crap out on you it could be a defective GFI, or one that's been reset too many times. Replace it, see if that solves the problem before going for service.
Estragon said:Do you know if a 300w psw inverter (eg Morningstar) start the GE fridge?
Have you caught the defrost cycle yet?
Just an update. I have been searching inverter fridges for use to replace LP fridges for an large off grid client. It seems that the LG series is not available in the US for some reason. (Maybe because they us butane for compressor gas?) That said, the are available all over Canada in the big box stores and they are quite reasonable priced compared to new LP fridges. Under $1000CDN for a 18 cu ft, linear inverter.
What I am searching for is some real world daily consumption figures. Clearly these will start and run fine on reasonably small inverters and battery banks assuming the batteries are healthy.
Tony -
Hey Tony. Not a great time right now for getting LG.... This year sucked! Below is a model that I have used for homes. They also make a 22 cu ft that is really nice also. The US energy star specs seem to be off on the high side for what I measure and give my clients for options. The 22 LG with the linear compressor can be had for about 1.2K on sale, uses 1.3kwh. The link below for the 25 uses about 1.5 KWH per days. Both are excellent. I use the Canadian energy star numbers. Much more accurate. US is high for offgrid minded.
https://www.homedepot.com/p/LG-Electronics-25-50-cu-ft-Bottom-Freezer-Refrigerator-in-PrintProof-Stainless-Steel-with-Filtered-Ice-LRDCS2603S/312284005
I just am not seeing the linear compressor in an 18 like you want. Maybe you could get a model number from the LG US site and then search with it.
Stay safe up there!"we go where power lines don't" Sierra Nevada mountain area
Thanks Dave. I am looking at the large ones, and they run~$1,500. They would certainly be sustainable in the system I am designing, and very cost effective compared to L/P. Factor in fuel cost and depreciation of each, and the solar pays for itself quite quickly, even factoring battery depreciation.
Tony -
It has been that for over10 years in my opinion for abandoning LP for cooling.
Probably closer to 20 years for a home or anything with a Lady involved Merry Christmas!"we go where power lines don't" Sierra Nevada mountain area
The inverter fridge sounds like a great idea. However, it appears that they are hard to find. A regular fridge does have a starting surge, but if my old DR 1500 can start one, something comparable in size with a conventional compressor should be able too as well. IMO any solar system running as fridge should have at least a 1500 watt inverter anyway.Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
Dave Angelini said:It has been that for over10 years in my opinion for abandoning LP for cooling.
Probably closer to 20 years for a home or anything with a Lady involved Merry Christmas!Lol but agree completely. I ditched the propane fridge years ago.I have one of those bottom freezer units in the link. Seems to be 50-55 watts when running. -
https://www.lg.com/nz/fridges/lg-GB-455P
This one is great . 300 kw per year . I measure it as less in our temperate climate.2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
The link you gave petertearai does not work in North America or ? I know what you mean though about the climate. Our summer energy is much lower (heat pump cool) than winter when we have a fire at night.
Ever try measuring it over 24 hours jtdiesel65 ? About 1.6 for the one in the link below. My neighbor has one.
Hmm didnt work for me either , should have tested it .
Maybe this one
https://www.lg.com/nz/fridges/lg-GB-455PL
However i suppose academic if not offered in your market .
24 hours 2 450 l lg fridges running . But no one in residence .
⁷
Nice ! The one I linked does have a defrost blip in 24 hours. Looks like yours don't?
We could get that number way up for you. I think my better half uses the light from the refrigerator more than most"we go where power lines don't" Sierra Nevada mountain area
Check on power factor for inverter refrigs. U.S. does not have regulations on residential power factor so manufacturers can save some cost by just using a simple rectifier-filter cap giving a PF of 0.6 to 0.7. For grid powering it is not a big deal but if running on an inverter or generator it creates more loss due to higher peak current.
I have a Samsung inverter refrig and has very poor PF. I would not have bought it if I knew.
Europe is different story. They require PF correction if appliance draws more then 75 watts. -
Yes Dave . I've looked back through the day logs doesn't look like a defrost blip . Unless optics can't catch it . Pretty sure the fridges are frost free. Ie i haven't defrosted them ever . Not sure of power factor.2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
The specs look really good. Larger than my fridge with similar power requirements. What is the price? (NZ dollars ok I have the conversion)Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
petertearai they both are on with frozen & food in them, just nobody there? Seems a bit better than I can imagine.
The 22 cu ft LG in NA is about 1.4kwh per day in normal use.
Yep both on with freezers full and a small amount of essential supply's .( wine ) In fridges . $ 1800 this includes our 15% gst tax . This second one was on special . Unfortunately i don't have my power measuring thing here at moment . But may try a measure with it , next year , i think it also measures power factor . But for $ 25.00 don't know how accurate it is .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
Thanks ! You guys have great wines. Got some from Costco last week! I have to do the math on cu ft to get an idea of volume but with those numbers I would not be concerned. There is error in Optics also when the power is that low.
Even if it was 200 watts for the two it is pretty nice. Any where near 25C in the structures or is it colder?"we go where power lines don't" Sierra Nevada mountain area
Maximum minimum thermometer shows 15 to 25 deg C for the last week . Thanks for the info on optics. So they could well be using more . I will re measure with the power meter, from memory when i checked the first one . It measured .7 of a kw per day averaged . After a initial 24 hour cooling down .
My daily usage is quite a bit less than the solar input , i put this down to inverter tare and internet modem .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
For the benifit of those who my be concerned about power factor of inverter based refrigerators, the actual battery consumption is what the unit is rated for, excluding inherent inverter losses. Power factor applies to the generating source, in the case of offgrid the DC-AC inverter, it will need to support the apparent power, for a 100W load with a PF of 0.6 it would be approximately 160W, if this is a small fraction of the systems ultimate capacity then it's generally a non issue.
Using the 100W PF 0.6 example, it would run on a 300W DC-AC inverter, this cannot be said for a conventional refrigerator which would need to account for starting surge thus needing a larger DC-AC inverter.
The overall efficiency gains of an inverter based refrigerator in general, isn't that significant, but rather they have the ability to maintain a more consistent temperature by modulating the compressor speed, as opposed to an on off situation of a conventional refrigerator. The newer more efficient refrigerants such as R32 and R600A along with linear compressor technology are where the real gains are found, they can be 30% more energy efficient.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
