mutiple inverters vs. single inverter?
Thick8
Thick8 Registered Users Posts: 49 ✭✭
edited August 2018 in Solar Beginners Corner #1
Do you guys have different inverters for different zones of your house? I'm currently taking the kill-o-watts around the house to get accurate measurements of what draws what. Other than the pool pump (120v), dryer (240v), sprinkler pump (240v), and 4 ton A/C unit (240v) we don't use a lot of power (will be more accurate tommorrow). The water, heat, and stove are all gas.
Looking at 48v to 120/240v systems.
  • mcgivor
    Multiple inverters can save battery reserve if using a larger main inverter which has high self consumption, for example my inverter uses ~40W, the only loads at night 6pm-6am, are the refrigerator (inverter type ) 50W intermittent and a few 13w led lights. What I came up with is feeding a second 300W inverter and the main inverter into an automatic transfer switch, the larger being the prime source, then programed an inverter block between these hours which transfers to the standby source, small inverter, the result is a dramatic reduction in the depth of discharge. The automatic transfer switch cost less than $30, batteries are much more expensive, depending on equipment, there  may be more complexity involved and naturally the larger loads must never come on.
  • Estragon
    I have a similar multiple inverter system, with larger loads wired to a sub-panel that only gets fed by big inverters/generator. It's still possible for someone to plug a hair dryer in to an outlet when fed by the small inverter, but the little inverter will just scream and go lights out.
    Good to know 300w will run an inverter type fridge. Hopefully they'll be reasonably available here in the next few years.
  • ScarlettJohn
    ScarlettJohn Registered Users Posts: 2
    Well, I don't have any inverters, but I am thinking about it now.
    This post really makes sense.
    edited August 2018 #5
    I had the electrician wire the house into 2 Distribution boxes and am just waiting for MidNite to release their 24V (new) inverters, then at night a 200W would do the trick...
    Dave Angelini Solar Expert Posts: 7,091 ✭✭✭✭✭✭
    If you are even thinking of powering the loads you mention, a small inverter would just be spending time on something that some might say is time wasted.
