VancleVector: well pump popping breaker
This discussion was created from comments split from: Automatic Transfer Switch issues (?).
    Either the genset (?) Cannot power the pump, or the pump takes a lot of current to start (bad starting capacitor  low genset voltage, etc.).
    Try wiring to the genset directly. Long wire runs with too much voltage drop?
    Bill
    With the generator un-wired, probe the connection points and verify you actually have 240V there and not 120V
  • mcgivor
    edited July 2018 #4
    What other loads are applied to the generator?  A battery charger for example could be drawing a significant amount of current, but without details, one can only speculate.
