How does solar panel works.
barryalen1992
Registered Users Posts: 1 ✭
Like I know that it is supposed to transfer the sun light in to power or anything, but I really want to have a deep understanding about how it actually work. Is there any thread in this forum can show me a completed guidance of my problem
You could start by reading the information on this link https://science.nasa.gov/science-news/science-at-nasa/2002/solarcells1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Is your question about how a "solar cell" works... Or how to design and build an entire solar power system (solar panels + charge controller + battery bank + AC inverter)?-BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
It's actually not that complicated. Solar cells (also called photovoltaic cells) are able to convert sunlight directly into electricity. These solar cells are connected electrically between each other and packed together in a unique solar panel. Electricity is produced since solar cells are usually made of materials such as silicone, which transfers electricity. I hope this was clear.
You can find my source for more info on solar panels here. Have a great day :-)
Silicone may be good for caulking and breast implants but not for photovoltaic cells.
Actually silicone plays a pivotal part in the conversation of sunlight to electrical energy,with added impurities. To blanket silicone as a caulk, or a liquid in a bag used for female enhancement of mamallian protruburances is eronious, silicon comes in many shapes and forms, both solid and liquid.
Silicone (a polymer, of which silicon is a component) is non-conductive. I used water-resistant silicone filled wire nuts to temporarily connect my silicon based winter pv panels.
I also plan to use silicone as a non-stick release component in forms to contain an epoxy kitchen countertop I'm making. Silicon wouldn't work very well
- 621 Discussion Forums/Café
