8v golf cart batteries,howe to wire for 24V?
patdufo
Registered Users Posts: 9 ✭✭
I have 6 8v golf cart batteries and I am trying to make 24v?series conection that I used with 4 6v batteries doent work because I am left over with 2 positive and 1 negative?every way that I tried ended up 16v?
Maybe I'm not seein what you're sayin. Wouldn't that configure as 3S/2PREC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
There is no way with 6 × 6V batteries to achieve a series parallel configuration for 24V, it's either use 4 in series ~ 200Ah, or 8 in series parallel, 4 in each string × 2 for~400Ah.patdufo said:I have 6 8v golf cart batteries and I am trying to make 24v?series conection that I used with 4 6v batteries doent work because I am left over with 2 positive and 1 negative?every way that I tried ended up 16v?
Edit. Disregard abuse statement for 8 volt batteries.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
8 (eight) volt batteries... Yes, 3x in series by 2x parallel strings (6 batteries total).
Should work fine. Make sure they are fully charged (or each battery at a similar level a charge--You don't want a discharged battery in series with a charged battery--If you "equalize" the battery bank (over charge at ~30-32 volts), you are pushing excessive charging current through the full battery to get charging current to the discharged battery.
Missed the 8 volt, need to buy some stronger reading glasses.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
